Thread: e85 mixing no mods
Page 5 of 5 FirstFirst ... 345
Results 81 to 85 of 85
  1. #81 Re: e85 mixing no mods
    Jan 2013
    United States
    Quote Originally Posted by Daheazle View Post
    I have lots of first hand experience with e85 in non e85 vehicles. Most of the ones i see are done accidentally or by people that dont know any better. I have been clear saying that if you keep the alcohol content low enough that your fuel trims are never maxed (that means, hot/cold, idle to wot and everywhere in between) it wont hurt a thing. I cant tell you how high the mix can be to not go over the threshold but considering you have fuel trims over 24 at wot yours is too high. Lower the percentage a bit more and see what happens. Just start adding a gallon of fuel to your tank at a time. Once your fuel trims are not maxing under any condition take a fuel sample to a dealer and get them to test it for you. Then you will know the exact alcohol percent you can safely use. If you live close to the desmoines iowa area i would test it for you.
    Sent from my SCH-R970 using Tapatalk
    Thank you for a real response. I'll try 6 gallons of e85 and 8 gallons of 93 next time and see what I get. Do dealers charge for a test?
    Sent from my Galaxy Nexus using Tapatalk
  2. #82 Re: e85 mixing no mods
    Dec 2013
    If you brought in a fuel sample in a glass bottle. I would think you could get them to do it for free. You only need 3 oz or so. You might want to call ahead and make sure they have a fuel composition tester (they should as its an essential tool)
  3. #83 Re: e85 mixing no mods
    Jan 2013
    United States
    Best way to sample on a car without a serviceable fuel filter....?
  4. #84 Re: e85 mixing no mods
    Dec 2013
    Lots of fuel pressure gauges have an air bleed valve and hose. Just hook the gauge to the service port, start the engine and bleed the hose into glass bottle. Use a snapple bottle or something similar. If you cant get to a fuel pressure gauge like that just take the feed line off of the rail and get someome to key it on for you
  5. #85 Re: e85 mixing no mods
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    Wondering if his car is still on the road today.
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  1. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  2. Mixing MAF Sensors
    By GP Modder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2012, 10:24 AM
  3. Coolant mixing?
    By MyPrixGT06 in forum General Tech Discussion
    Last Post: 01-03-2011, 10:29 PM
  4. Mixing Apperance Packages
    By Shake_Zula in forum Visual/Body Modifications
    Last Post: 02-09-2009, 08:56 PM
