Thread: block heater
Results 1 to 13 of 13
  1. #1 block heater
    May 2011
    winnipeg
    Can anyone tell me why a block heater would start to make a humming sound after three years of running quiet? Has anyone else noticed this noise? It is in a 2004 grand prix 3800.
  2. #2 Re: block heater
    Good question, and I don't really have a clue either.
    The factory block heater on my car doesnt make any noise that I know of, though it does sit outside plugged in while I sleep haha.
  3. #3 Re: block heater
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    FWIW, I have heard diesel block heaters in John Deere tractors and cat powered semis make a hissing sound. When I was growing up, that is how dad taught me to check to make sure it was working.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  4. #4 Re: block heater
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Mine makes a hissing noise sometimes as well. The colder it is the quieter it hisses. Not sure why but I do know one thing. When I go outside tomorrow morning my scangauge is going to say 100*F even though it is below zero outside. I love my block heater
  5. #5 Re: block heater
    Omaha, NE
    I could be way off here, but it could have something to do with the adhesive getting warm.
  6. #6 Re: block heater
    Quote Originally Posted by frosty View Post
    Yours must be better than mine or you keep it running all the time.
    I run mine on a time delay to turn on 3ish hours before I leave in the morning if I work and that will keep it at +50 of the ambient temp outside, normally. Like this past weekend it was -10 overnight, car was +45-50 when I went to start it.
  7. #7 Re: block heater
    Pennsylvania, USA
    Why do you guys run one? I never had problems starting my car with synthetic oil at about -5, is it to prevent what from cracking as it heats up?
  8. #8 Re: block heater
    GT Level Member WolvesSoulZ's Avatar
    Québec
    It makes it easier to start up, far easier, plus you don't need to let it running for long to have heat, as usually, as soon as you crank it up after it being block heated, you are near to have your heat.
    I don't use mine unless it's colder than -10F, right now it's just -6F so it's tolerable. (Not so tolerable for us, as with the winds it's -36F right now.) When it dips bellow -30F without the winds, I usually plug it on in the night to make sure the coolant doesn't go too cold, as it's just 50/50.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  9. #9 Re: block heater
    Pretty much what he said. Most people in super cold climates run it to prevent the block from cracking, even a 70/30 mix of coolant will only be good down to -30 to -40 degress at the most. ( Thats the temp of the coolant itself, not the air.)
    I run it so I don't have to let it idle for 10min to get heat and defrost my windows, it'll only take half the time to get hot heat with it plugged in. Aswell as making it way eaiser on the entire lower end of the engine. When the oil is so cold its harder for it to move around and its slower and does not do its job as good as it could when its warmer.
  10. #10 Re: block heater
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Were your block heaters factory installed or you bought them aftermarket?
  11. #11 Re: block heater
    some cars came with them from the factory, others had them installed as a dealer option, and of course you can buy and install one your self. they run about 35 bucks. it replaces a freeze out plug.
  12. #12 Re: block heater
    Never Never Land
    The block heater on my prix makes a humming kind of noise. My diesel doesn't though. Factory heaters on both. Idk why It does it. Never really cared lol
  13. #13 Re: block heater
    Apr 2011
    South Dakota
    I had to replace mine once so it might be a higher wattage. I leave it plugged in all night.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. Where is the block heater?
    By mngtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2013, 09:48 PM
  2. gen V L67 long block or short block.
    By Jtg1551 in forum Wanted To Buy - Parts
    Last Post: 06-14-2013, 12:54 PM
  3. Block Heater Plug
    By Moe Dubs in forum General Tech Discussion
    Last Post: 12-12-2011, 06:44 AM
  4. Block Heater
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-25-2010, 11:49 PM
  5. block heater
    By tod1d in forum General Tech Discussion
    Last Post: 12-16-2008, 08:26 PM
