Thread: heater won't blow hot air
Results 1 to 8 of 8
  1. #1 heater won't blow hot air
    Dec 2013
    Slinger
    2008 - I can't get hot air to blow from the heater. I changed the thermostat. I've checked the hoses to see if one if one if cold, however both feel warm so don't think there's a clog. Suggestions?
  2. #2 Re: heater won't blow hot air
    Ohio
    Heater core could be clogged. What thermostat did you put in? Regular 1 year Stant or the superstat lifetime?
  3. #3 Re: heater won't blow hot air
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    How hot does the car get? Cause I know my 04 won't blow hot air until it reaches half way, also check coolant levels .
    Sent from my iPhone
    2004 Grand Prix GTP 150,000 " The New Edition "
  4. #4 Re: heater won't blow hot air
    Back flush the heater core.
  5. #5 Re: heater won't blow hot air
    mine blows heat when it just starts to register on the temp gauge.
  6. #6 Re: heater won't blow hot air
    Jun 2011
    Texas
    If both heater hoses are warm then there is good flow through the heater core. Your problem is inside the car, check the temp door actuator and knob
  7. #7 Re: heater won't blow hot air
    Ohio
    He said the radiator hoses. Not the heater hoses
  8. #8 Re: heater won't blow hot air
    Omaha, NE
    OP, Post back! We miss you!
  1. why did my engine blow and what should i do
    By ameliapalooza in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2012, 08:28 PM
  2. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  3. Can flushing your lines cause a heater core to blow?
    By Sazy in forum General Tech Discussion
    Last Post: 01-25-2011, 08:28 PM
  4. Taillight blow out
    By jluca in forum General Tech Discussion
    Last Post: 12-04-2010, 08:22 PM
  5. blow out
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 11-26-2009, 06:14 PM
