Thread: engien swap
Results 1 to 12 of 12
  1. #1 engien swap
    Aug 2012
    ELIZABETHTown,NC
    after switching engine out to one that was better all parts are the same but after I got it all togather it run bad I get 8 diff engine code help
    it 2001 grand prix se 3100 it had 280000 it smoke a lot so got another car low mileage just swap motor an trany an get all the code
    crank sensor low voltage cam sensor an mas air sensor all read low voltage.
  2. #2 Re: engien swap
    Dec 2010
    DMV
    Gonna need a lot more info sir.
    What engine was swapped.
    Which sensors are left?
    Have any pics?
    What car do you drive?
    Basically,
    Help me help you.
    Sent from my HTC One using Tapatalk
  3. #3 Re: engien swap
    I'm going to guess you swapped an L67 into a 4 cyl grand am. Good work in making run
  4. #4 Re: engien swap
    Dec 2010
    DMV
    Lmao
  5. #5 Re: engien swap
    way more info needed, what engine came out, what went in? (years of both) what are these 8 codes you got? does it run at all?
  6. #6 Re: engien swap
    Ontario
    This thread needs a grammar and proper sentence composition mod.
  7. #7 Re: engien swap
    Omaha, NE
    Quote Originally Posted by byard View Post
    I'm going to try to translate this to english:
    I have a 2001 Grand Prix SE with a 3.1L engine that had 280,000 miles. The engine smoked alot, so I got another lower mileage car to motor and trasmission swap. After the motor swap, my check engine light engaged and I received 8 codes, including Crank, Cam and MAF low voltages.
    Based on the codes and generally vauge description, I'm going to say something isn't right with your PCM, or you forgot to plug in your wiring harness.
  8. #8 Re: engien swap
    Personally..I'm thinking battery connections or grounds
  9. #9 Re: engien swap
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    I think he has an oil leak.
  10. #10 Re: engien swap
    Omaha, NE
    Quote Originally Posted by TwiztdWun View Post
    How did you come to that conclusion?
  11. #11 Re: engien swap
    Feb 2013
    Ohio
    With the limited amount of info given ( and the inability to at least make an effort in grammar, punctuation and sentence structure ), it is about the equivalent of someone asking " Car leak oil....You tell me where from? ". So anytime I see one of these posts with little to no info, my response is going to be " I think he has an oil leak ."
  12. #12 Re: engien swap
    Omaha, NE
    I won't disagree with that logic.
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
