Thread: DIC light
Results 1 to 8 of 8
  1. #1 DIC light
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    What lights up the LCD board of the DIC? half of mine is dimmer than the other half.
    Thanks!
    Sent from my ADR6425LVW using Tapatalk
  2. #2 Re: DIC light
    SE Level Member trey9778's Avatar
    May 2013
    Orlando, Fl
    97-03 or 04+
  3. #3 Re: DIC light
    Feb 2009
    Roanoke, VA
    97-03, it's a 2002
  4. #4 Re: DIC light
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    bulb is burned out easy fix
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  5. #5 Re: DIC light
    Feb 2009
    Roanoke, VA
    Awesome, just a simple bulb that can be found at an auto parts store or is it one of those specialty bulbs?
  6. #6 Re: DIC light
    May 2013
    Orlando, Fl
    I bought my 02 3 months ago and it had the same issue. the right side was dim compared to the left side. pull the dash bezel off on the pass side of the dash. bend the tab on the right of the dic to remove it. go to the junkyard and find a few gtps with the same DIC. remove each light bulb and hold it up to the sunlight to see if it has burn spots on it. if not there you go. like gpse2000 said. very simple.
  7. #7 Re: DIC light
    Dec 2008
    Lawndale, CA
    A #24 bulb is often used as a replacement. Simply remove the existing bulb and replace with the #24. But I believe the actual size of the bulb is a PC74. I haven't looked at the bulbs in a long time but I recommend you remove the bulb and take it with you to the store and compare it against the PC74. If it is not carried anywhere locally then a #24 will fit.
  8. #8 Re: DIC light
    Feb 2009
    Roanoke, VA
    Just finished swapping in #24 bulbs, worked great!
  1. driver side parking light and fog light not working
    By shelbyguy04 in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2013, 01:37 AM
  2. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  3. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  4. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
