Thread: Old Thread
Page 8 of 8 FirstFirst ... 678
Results 141 to 159 of 159
  1. #141 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Aug 2012
    MIAMI
    Quote Originally Posted by z3r0 View Post
    Low tire pressure light
    Mines too
    Sent from my HTC Sensation 4G using Tapatalk
  2. #142 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    May 2012
    Where winter never ends
    1) 04 GP Security system/Can bus issue (easy fix)
    2) PCV system is gone because of turbo
    3)Dirty
    4)Exhaust leak
    5)Too fast...too many tickets :P
    2000 Regal - Winter Beater
  3. #143 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Quote Originally Posted by Below Average Joe View Post
    I drive a cavalier........
    Me too.
    Or something like that.
  4. #144 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Aug 2011
    'Merica
    Quote Originally Posted by blueguy View Post
    Me too.
  5. #145 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Sep 2013
    Northwest Indiana
    all my struts are bad
    all the wheel bearings are bad except one lol
    the drivers side door is missing the secondary seal(thin one that helps with wind noise) and its still quieter than my 90 bonneville that had good door seals
    needs valve cover gaskets
    cooling fans dont work
    coolant system has air in it and I cant seem to get it out
    I think I stripped my passenger side wiper arm cuz it only half ass works
    needs heater blend door actuators (how much would a gm dealer charge to do this?)
    alarm goes off randomly for a second or two. cant be bothered to fix that one
    am/fm only works if its warm outside
    my headlight switch and hud switch don't light up, I replaced the headlight switch itself and still dosent work (suggestions?)
    heat extractors on hood are fading a bit
    front bumper is cracked (have a new one for spring)
    rockers are rusty
    motor and trans mounts are shot
    and drivers side seat is ripped a bit
    runs like a top tho lol
  6. #146 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Where do you live in IN? I could help you with most of that
  7. #147 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Sep 2013
    Northwest Indiana
    That would be awesome lol. I live in Portage IN, about 30 min east of gary or an hour from chicago
  8. #148 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    You are quite a while away. About 4 hours or so.
  9. #149 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Jan 2014
    New Knoxville Oh
    Been on a six hour road trip and had heat the whole time till now it blows hot on drivers cold on pass anger then the driver just gets cold after a few sec any ideas
    Taz238
  10. #150 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Check your coolant level and if it's fine flush your heater core
  11. #151 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Jan 2014
    New Knoxville Oh
    How do u do that?
    Taz238
  12. #152 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    May 2011
    ohio
    i just replaced my water pump had a bad baring.
    sway bar on the passagerside is in two
    i have a slow leaking brake fluid leak
    i have had no abs or traction control for a year now (dont care to much about fixing that tho)
  13. #153 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    SWPA
    Quote Originally Posted by zach101 View Post
    For the slow brake fluid leak check your calipers. My right rear was leaking at the ebrake mech.
  14. #154 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Quote Originally Posted by Taz238 View Post
    Taz238
    search blend door actuator
  15. #155 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Mar 2012
    NC
    What's wrong with my car...there isn't enough words to explain. The lack of a 3800 turbo is a big one. LOL The fact that the stock 2.2 needs cam bearing and has low oil pressure is the other.
  16. #156 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Feb 2013
    37.295091, -121.930053
    well you have 25000 letters (per post) to tell us all about it.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  17. #157 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Pennsylvania, USA
    1. Transmission solenoid issues, most likely the PCS. Replacing that, the TCC, and the 1-2 and 2-3 shift solenoids this weekend for peace of mind.
    2. Exhaust leaks, one by the resonator flange, and one or two up around the manifolds. That's a summer project.
    3. Rear SS brake lines got rubbed through, didn't know they were rubbing until the insulation was gone :/ I think I have air in the lines too, the pedal should be more firm I suspect.
    4. Misc. exterior issues, like some paint that needs touching up and a reverse bar that needs clearing and sealing.
    5. A/C doesn't work, due to a leak. Another summer project. Probably get a used compressor from Morad since mine seems to have aloud bearing, and get a new evap canister and orifice tube. I'll pick up a gauge set and a vacuum pump and do it all for under $100 myself
    Overall not too bad for my first car. I got it (an 05 N/A) at 59,000 as a rental for my last year of high school in 2010. Within a year (after the warranty of course) it had so many problems from LIM gaskets and sticky lifters, to random stalling and Max Adapt shifts almost breaking my back. Now at a bit over 100k I'd wager to say I have to most reliable car of my family. I don't baby the car either, just ensure I'm very good with maintenance and catching things when they start. It also helps that I'm going to school for an auto tech degree, so I've got access to lifts and such whenever during the week days.
  18. #158 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Posting in this thread to bring it back up, since I bought a new GP.
    So here's the new list:
    Clear coat fade like hell on the hood and starting on the roof. Havent decided what to do with this yet, either keep a beater bomb or repaint. Will need repainted before winter.
    A little surface rust near the back strut tower. Nothing like the 99, though. A nuisance, not a menace at this point, but will need welded before winter.
    Front bumper cover is cracked. May fix this.
    Windshield washer pump is broken. I'm going to replace this. Thing is, I need to take the front bumper cover off to get to it, so I might end up replacing the bumper cover anyway.
    Stock radio head unit has a soldering problem, the thing doesn't light up. If I upgrade I'll go aftermarket so I can get an aux jack.
    Stock head lights and tail lights all suck. Checking the junk yard tomorrow ISO some non-ratty tails.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  19. #159 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    My list keeps growing. CAuse I'm doing nothing!
  1. "wrong" struts wanted for front of 97GTP to raise it..
    By darkhorizon in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2013, 07:47 PM
  2. Replies: 3
    Last Post: 07-15-2013, 12:53 AM
  3. Can't post a New Thread in the "For Sale - Vehicles"
    By sandite5 in forum Off Topic Discussion
    Last Post: 06-04-2010, 05:30 PM
  4. Not letting me post a "For Sale" thread! WTF?
    By 01SmokedGtP in forum Introductions/Noob Questions
    Last Post: 04-29-2010, 10:13 PM
