Thread: 1999 Grand Prix gt won't start
Results 21 to 40 of 45
  1. #1 Re: 1999 Grand Prix gt won't start
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Dont you mean 19 is crank position sensor? Not cam sensor?
  2. #2 Re: 1999 Grand Prix gt won't start
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Have you unplugged the MAF and tried it to see if it would run? You said you got it to run but it was rough and only when you stayed on The gas.
    Your 3.8 doesn't have a belt, it has a chain. The can sensor is below the water pump right above the balancer.
    If you have a good scanner you can check the correlation of can and crank sensors while its running.
    My 2000 GTP was missing badly and would only run under Heavy throttle when my maf went out. My exhaust was also Glowing red all the way to the mufflers at the rear of the car.
    And once you step on the throttle the IAC has no affect on the car, it ONLY functions at 0% throttle input. So that's not it.
    #23 is the cam sensor. There are no knock sensors in the diagram you posted.
  3. #3 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Yup tried unplugging it, still nothing.
  4. #4 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    19. SENSOR. Distributor (also Knock Sensor)
    SENSOR,CR/SHF POSN(4 PIN)(ACDelco #213-151). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (1997-2003) (1999 - 2003). Required: 01
    SENSOR,CR/SHF POSN(4 PIN)(ACDelco #213-151). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (2000-2005) (2000 - 2005). Required: 01
    23. SENSOR. Distributor (also Knock Sensor)
    SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (1997-2003) (1999 - 2003). Required: 01
    SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (2000-2005) (2000 - 2005). Required: 01
    SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36),3.8-1(L67) (2004-2004) (1999 - 2004). Required: 01
    SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: WB 3.8K(L36) (1999-2003) (1999 - 2004). Required: 01
  5. #5 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Do we have an explanation to why it smokes so bad?
  6. #6 Re: 1999 Grand Prix gt won't start
    Jul 2013
    Summertown Tn
    Both of the sensors are magnetic impulse sensors that read a relucter ring and send that signal to the ecm.
    The knock sensors are on the lower front and rear of the block and screw into The water journals and read harmonic vibrations from the engine. They are not the knock sensors.
    Its smoking probably because its running rich. Keep it running for about 2-3 minutes and look under the car to see if your pipes are glowing.
  7. #7 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Doesn't stay running, as soon as I let off the gas it dies immediately. If it was running rich, that would be something with the air fuel mixture
  8. #8 Re: 1999 Grand Prix gt won't start
    Jul 2013
    Summertown Tn
    Exactly. That's why I'm saying try the easiest thing first. MAF sensor. If it doesn't work you can always take it back for a refund if you buy it from a parts store. But at least you eliminated one thing.
    Mine didn't clear up when I unplugged it, but it didn't seem to be as bad.
  9. #9 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    I Beleive I did it with the car running. Yes I pulled on the right sensor
  10. #10 Re: 1999 Grand Prix gt won't start
    Jul 2013
    Summertown Tn
    Did you unplug it with the car running or did you unplug it then try stating the car?
    Make sure the ignition is off, unplug the maf then start the car. this may be a stupid question, (i mean no disrespect) but you are unplugging the right sensor arent you? The sensor on top of your throttlebody.
  11. #11 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Ok Ill run down to the autoparts store tommorrow and grab one. Ill report back.
  12. #12 Re: 1999 Grand Prix gt won't start
    Jul 2013
    Summertown Tn
    Unplug it with the ignition off, then try starting it. Go try that real quick and report your findings.
  13. #13 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    Still didn't answer if there are any codes lol.
  14. #14 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    I Googled this.
    IAC Valve and Outside Air Temperature Sensor. (plugged into the flexible tubing on your air intake box)
    Just sayin.
    Unplug your battery, touch your cables (positive /negative) together, clean these 2 things.
  15. #15 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    I bow down to you thom, it is the maf sensor! I realized I ply took it off with the car running, never thought that leaving it off would make a difference !
  16. #16 Re: 1999 Grand Prix gt won't start
    Jul 2013
    Summertown Tn
    Quote Originally Posted by Yamahakid88 View Post
    So it did end up being the MAF.... Glad we could help.
  17. #17 Re: 1999 Grand Prix gt won't start
    makes a big difference, un plugging it when off, then starting it puts the car in open loop. pre set settings.
  18. #18 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    I did not know that! Thanks to all who helped, I owe you guys a beer if your ever in northern illinois
  19. #19 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    K&N filter?
  20. #20 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    Before replacing it, clean it.
    MAF SENSOR CLEANER or ELECTRONICS CLEANER.
    Don't touch anything inside. Just spray. About a dozen quick passes.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. noobie. 1999 grand prix gtp hard to start issues. Need help!!!!!!!
    By curticra in forum Introductions/Noob Questions
    Last Post: 01-02-2013, 05:16 PM
  3. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  4. I need some help with my 1999 Grand Prix GTP!
    By Melissa91 in forum General Tech Discussion
    Last Post: 05-24-2011, 08:24 PM
  5. 1999 Grand Prix sometimes won't start
    By sabram in forum Canada
    Last Post: 09-13-2009, 07:31 PM
