everytime I push on the break pedal I've got fluid coming out of one of the black round seals at the back of that distributor block does that mean my block is bad or is one of my calipers bad
I'll have to get a pic tmw. The block sits just in front of the master cylinder. The lines from the master cylinder(m.c.) go into it. If u look on the side toward the m.c. u can see two black plastic flat discs. The one toward the fender is leaking when I push on the brake
abs module?
cylinder is 2 lines out, 2 lines into abs, abs is 4 out. only other "blocks" are on each rear line. ur line/bubble flare probably rusted out.
The metal line itself? The abs module/block has four colored dots on it and and cylinder-like thing under it. I tought about just supergluing the black disc in place
I have no idea what this black disk is. abs is 4 top and 2 back. Picture?
