Thread: Coolant level sensor bad??
Results 1 to 10 of 10
  1. #1 Coolant level sensor bad??
    SE Level Member trey9778's Avatar
    May 2013
    Orlando, Fl
    Does anyone know what could be the issue here.. As soon as I saw the light, I stopped and checked the coolant level and it was fine. After letting the car cool off for about 2 hours the level is still fine. Its obviously not overheating and there's no odor of coolant coming from the engine anywhere as well as no leaks or smoke/steam. I'm assuming its the coolant level sensor. The car is an 02gtp. Thanks for reading.
  2. #2 Re: Coolant level sensor bad??
    Dec 2012
    Where 4T65E's were born
    the sensor is either dirty or bad. its on the side of the rad, cap side, you'll see the wire leading to it.
    take it out, clean it, if it still acts up, change it. this is of course providing your rad is full. yet the light comes on.
    Taken from another forum post ^
    Sold.
  3. #3 Re: Coolant level sensor bad??
    cool, i dont have to type that up now lol
  4. #4 Re: Coolant level sensor bad??
    Dec 2012
    Yeah lol. I remember seeing it a while back. I was like ehh, I couldn't have said it better, might as well find it and copy/paste.
    Sold.
  5. #5 Re: Coolant level sensor bad??
    May 2013
    Orlando, Fl
    Thanks for the reply. I shall replace it at once! lol the light is flickering between on off and on but very dim. I just wasn't sure judging by how it illuminated in the video if that was the cause.
  6. #6 Re: Coolant level sensor bad??
    Just unplug it and forget about it
  7. #7 Re: Coolant level sensor bad??
    Dec 2012
    I'd try cleaning it first, they're not cheap for what they are. If cleaning it doesn't work, I'd say go to a junk yard if you really care about it, just make sure it's clean. I mean, advance sells them for $52, rockauto's lowest is $36.
    Sold.
  8. #8 Re: Coolant level sensor bad??
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Quote Originally Posted by trey9778 View Post
    LOL seems like someone always has the same problem as me. On my 00 My coolant is fine but the light flickers really dimly and my 06 is almost dry in the reservoir but not a light on at all
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  9. #9 Re: Coolant level sensor bad??
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I have a bad sensor. I give zero sh*ts about it. I know it's not low so no biggy lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  10. #10 Re: Coolant level sensor bad??
    Then Just unplug it the light goes out
  1. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
