Thread: Missing coolant
Results 1 to 6 of 6
  1. #1 Missing coolant
    Sep 2013
    Wauwatosa Wisconsin
    I have a 2008 Grand Prix gxp that keeps missing coolant. For the past three days the reservoir has been a half inch under the specified amount after I top it off. There are no leaks that I can find anywhere and the car runs just fine but the temp gauge will go about a centimeter over halfway when running. With the hood popped there is a sound in the rear engine bay that sounds like a vacuum leak but I cannot locate the origin of the noise. My concern is whether or not is is a cracked head or internal head gasket leak. Has anyone else had this problem?
  2. #2 Re: Missing coolant
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Have you checked your oil? If you keep having to refill it, its a pretty good leak. It's going somewhere, whether it be on the ground or somewhere else. Poke around and see if you cant find any wet spots and trace it.
  3. #3 Re: Missing coolant
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    search lower intake manifold. may be the lim gasket.
  4. #4 Re: Missing coolant
    Quote Originally Posted by orange57 View Post
    hes got the V8.
    make sure your checking the level when the car is ice cold, like after being parked all night. the res level changes as the engine heats and cools. the rad takes and puts it back as needed.
  5. #5 Re: Missing coolant
    Aug 2012
    Chandler, AZ
    hes got the V8.
    woops. did not catch that.
  6. #6 Re: Missing coolant
    Sep 2013
    Wauwatosa Wisconsin
    Intake manifold is dry as a bone.
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. 3.1 missing
    By Jacob in forum Introductions/Noob Questions
    Last Post: 02-07-2013, 06:04 PM
  3. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  4. missing
    By bigrig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2011, 05:03 PM
  5. Do you see anything missing here?
    Last Post: 02-24-2009, 06:26 PM
