Thread: How to unplug coolant light? Help please
Results 1 to 6 of 6
  1. #1 How to unplug coolant light? Help please
    SE Level Member GTPontiacMan's Avatar
    Dec 2010
    TX
    delete
  2. #2 Re: How to unplug coolant light? Help please
    Dec 2010
    DMV
    You could snatch the bulb out, by pulling the cluster out
    Sent from my HTC One using Tapatalk 2
  3. #3 Re: How to unplug coolant light? Help please
    Feb 2008
    The coolant level sensor is on the passenger side of the radiator in front of the positive battery connection. Reach in and unplug it. Be sure to check your coolant level often, though.
    Sent from my SkyRocket
  4. #4 Re: How to unplug coolant light? Help please
    Quote Originally Posted by GTPontiacMan View Post
    So all have to do is pull out to unplug. It won't leak, correct?
    you can unplug it, yes. no it wont leak.
    you can also take the sensor out of the rad, clean it. cause its likely gunked up with dex sludge. then put it back it, good chance it will work right again.
  5. #5 Re: How to unplug coolant light? Help please
    Check it often? LOL
    Scott.. you'd think these guys never had a car w/o a level sensor on the rad. Sheeeeeeeeeeeet kids, when you smell coolant or see a puddle, that's when you check that out.
  6. #6 Re: How to unplug coolant light? Help please
    Feb 2008
    Check it often? LOL
    LOL, Bill! Just trying to cover all bases. Most people nowadays rely on a light to tell them when to do things...
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. How do you unplug a fuel injector?
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:03 AM
  3. How do I change/unplug the wires on my Turn Signal/Multifunction Switch
    By indygrandprix in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2013, 08:32 PM
  4. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
