Thread: where do i plug oil pressure gauge?
Results 1 to 11 of 11
  1. #1 where do i plug oil pressure gauge?
    Feb 2015
    california
    Just got glowshift oil pressure electric gauge and am wanting to know which sensor to plug it into and if i beed to do instal when doing an oil change?
  2. #2 Re: where do i plug oil pressure gauge?
    Nov 2013
    Wisconsin!
    You replace the factory oil pressure sensor by the filter with yours.
  3. #3 Re: where do i plug oil pressure gauge?
    Feb 2015
    california
    Is it best to do it when i do oil change? Wont oil come rushing out when sensor is replaced?
  4. #4 Re: where do i plug oil pressure gauge?
    have a pan ready to catch the oil, a little will come out. thats only 1/2 the fun, next you get to wire it all.
  5. #5 Re: where do i plug oil pressure gauge?
    Feb 2015
    california
    Cant seem to get the sensor out. Any tips?
  6. #6 Re: where do i plug oil pressure gauge?
    Feb 2015
    california
    Got sensor out but the glowsgift sensor is too small of threading...
  7. #7 Re: where do i plug oil pressure gauge?
    jack car up, take pass front wheel off, then reach in with channel lock pliers and un screw it.
    and you'll likely need this adapter to get the new sensor in the hole.
  8. #8 Re: where do i plug oil pressure gauge?
    Once you do all that work.. you'll realize as Scott did. It's not really worth much to have OP
  9. #9 Re: where do i plug oil pressure gauge?
    better then a gay ass boost gauge. at least oil pressure means some thing. and i had a hole to fill.
  10. #10 Re: where do i plug oil pressure gauge?
    Zero gauges ftw
  11. #11 Re: where do i plug oil pressure gauge?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Zero gauges ftw
    Agreed.
  1. oil pressure gauge or vacuum gauge?
    By silenthaven in forum General Grand Prix Discussion
    Last Post: 07-08-2015, 05:35 AM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. oil pressure gauge
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-09-2011, 02:00 AM
