Thread: 1999 Grand Prix gt won't start
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 1999 Grand Prix gt won't start
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Drove it this morning it was fine, when to go out for work a couple hours later, it wouldn't start. I hear fuel pump go on it turns over but will not start, I tried giving it gas. That helped a little, but not enough to start it. Please help ASAP guys. Thanks
  2. #2 Re: 1999 Grand Prix gt won't start
    Dec 2012
    Where 4T65E's were born
    Well if giving it gas helps, it's probably not the crank sensor. I haven't known a bad MAF sensor to make it impossible to start, but you could try unplugging it and see what happens. If that doesn't work, I'd check fuel pressure. It may turn on but not have enough pressure.
    Sold.
  3. #3 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    I'll try the maf, I'll probobly chek for spark next, could the fuel pump be going bad?
  4. #4 Re: 1999 Grand Prix gt won't start
    Dec 2012
    It's possible. Check the fuel pressure, could be the regulator as well. Pull the vacuum line off of it and see if it has gas in it.
    Sold.
  5. #5 Re: 1999 Grand Prix gt won't start
    GTP Level Member
    Oct 2011
    Raleigh, NC
    You sure it has gas ?
    1997 Red GTP 182000 miles stock
  6. #6 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Pretty sure yes. I unplugged the battery for giggles, checked the intake. Neither worked. T dark to try anything big. However, I push down on the gas pedal about half way and tryed starting it, it came to life as long as I kept pushing on the gas, it sounded like hell forte few seconds it ran, backfiring, sputtering, sounds awful.
  7. #7 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Anyone?
  8. #8 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    Plugs, Wire, intake, vacuum leak, Ignition Coil,...
    Any codes?
  9. #9 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    MAF wouldn't prevent it from starting.
    Clean your IAC valve. Coolant and oil levels.
    Fuel cap.
  10. #10 Re: 1999 Grand Prix gt won't start
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Try a MAF. mine was doing the exact same thing and a MAF fixed it. I borrowed one from a friend to try, then bought one when his fixed mine.
  11. #11 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Ok, finnaly found some time to poke around and try some things. This is what I found. Hooked up a code reader to it, all sensors are working properly and how they should. There is about 45 psi at the fuel rail which should be adequate, Tryed spraying starting fluid in the intake, and nothing. I also found that every single cylinder is misfiring. More than 30 times on each one O_O So if it was a coil pack, then just 2 cylinders would be misfiring, Any ideas?
  12. #12 Re: 1999 Grand Prix gt won't start
    bad icm maybe. you can take it out and have it tested, but they do tend to test good and still be bad time to time.
  13. #13 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Sigh, Im leaning toward Icm, crankshaft sensor, or where the coil packs plug in. I already have the crankshaft sensor, so i will try this first. What do you think about the coil pack theory?
  14. #14 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    If it were the MAF, you could unplug it and it would work.
    I'd start pulling the easy access parts and cleaning them with brake/electronics cleaner.
    ICM, that would DEFINITELY throw a code.
    Cam position /knock sensor is relatively cheap.
  15. #15 Re: 1999 Grand Prix gt won't start
    well the crank sensor and cam sensors tell the icm to fire the coils as needed. so something in that area is a problem if its got all 6 cylinders misfiring.
    maybe a bad harness to the crank and cam sensors, check that for damage.
  16. #16 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    It truly sounds like an ignition issue.
    Maybe, maybe the timing belt?
  17. #17 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    I retaped and loomed mine yesterday before I put it back on. The coolant temp sensor and Wiring harness near the radiator cap were looking pretty ragged too...
    Could be a silly short somewhere too.
  18. #18 Re: 1999 Grand Prix gt won't start
    Jun 2013
    Illinois
    Where is the cam sensor located? I highly doubt it would be anything along the lines of the maf sensor, iac etc. Otherwise it would still run even if it didnt work.
  19. #19 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    19 is cam. 23 is knock.
    That Harness is your engine Wiring harness. It plugs into your icm, runs along the belt, and over the top of your lim.
  20. #20 Re: 1999 Grand Prix gt won't start
    Banned
    Oct 2013
    Moorhead, MN
    Dirty iac can choke the engine and stop it from running.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. noobie. 1999 grand prix gtp hard to start issues. Need help!!!!!!!
    By curticra in forum Introductions/Noob Questions
    Last Post: 01-02-2013, 05:16 PM
  3. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  4. I need some help with my 1999 Grand Prix GTP!
    By Melissa91 in forum General Tech Discussion
    Last Post: 05-24-2011, 08:24 PM
  5. 1999 Grand Prix sometimes won't start
    By sabram in forum Canada
    Last Post: 09-13-2009, 07:31 PM
