Thread: How to wire subs?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: How to wire subs?
    Sep 2011
    Arkansas
    Www.knukonceptz.com MUCH better than bulls audio.
    Sent from my A200 using Tapatalk 4
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  2. #22 Re: How to wire subs?
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    how so?
  3. #23 Re: How to wire subs?
    Sep 2011
    Arkansas
    Larger wire with a thinner jacket than bullz audio. Much more for your money, and the more wire, the better (to a point). It's on par with Kicker, RF, Shok, etc. Also a higher strand count depending on which line you choose, which only allows more flexibility in the wire. For a modest setup, you'll be fine with the CCA wire, which is copper clad aluminum. I'd go ahead and run 1\0 OFC and be done with it personally, but the 1\0 CCA kit will more than meet your needs, and support future expansion via a distribution block should you decide to add a 4 channel. If you're just going to be done after subs, the 4awg kit will do fine.
  4. #24 Re: How to wire subs?
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    Make sure you have the right set up too. What ohms is your subs? What amp do you have? If you have a 1000w mono block 1ohm stable and have two 2 ohm kickers, chances are you'll eff something up if your wiring them in sequence. Also, sometimes the bigger the wire isn't always better. I have a top quality 4 gauge kit and it has some better ratings than cheaper 0 gauge, but each to their own.
  5. #25 Re: How to wire subs?
    Sep 2011
    Arkansas
    Quote Originally Posted by hammerline81 View Post
    That would apply to my mentioning OFC vs CCA and recommending knu over Bullz Audio. No worries of inferior quality.
  6. #26 Re: How to wire subs?
    Jun 2013
    Illinois
    Just came in the mail today. Looks pretty good, has absoulity everything, butt connectors, grommet etc.
  7. #27 Re: How to wire subs?
    Sep 2011
    Arkansas
    Sweet. Whatever you went with, it's always great getting new stuff. You'll be banging in no time.
  8. #28 Re: How to wire subs?
    Jun 2013
    Illinois
    I know it hah, its like Christmas when I get home
  9. #29 Re: How to wire subs?
    Jun 2013
    Illinois
    Well managed to get it all set up, and I must say, it looks pretty damn near professional. Thanks to all who helped
  1. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  4. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  5. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
