So... before I get all techie... on post # 6 you do realize you flamed yourself right??? You quoted your own posting #4 "I understand Torque is an android app, but the OBDII device is Bluetooth. I just don't understand why an iPhone can't even see it? Isn't Bluetooth always Bluetooth?" and then made a mockery of it all as a useless post!!! If you don't like what you have to say, maybe you shouldn't say anything at all... just sayin.
Now onto the techie'ness. After a brief talk with Google I have arrived at the conclusion, you don't know what you are doing. It's been 4 days and I took 5 minutes with Google to find the reason why. A little searching would have shown you why.
Its not so much that the bluetooth is bluetooth has problems connecting. You must use a Module that has Bluetooth w/ wifi to get the Iwhatevers to connect to it. Apple uses a proprietary Bluetooth stack meaning that the creator of Torque would have to pay Apple a fee to use their stack instead of an industy standard one for the Droids, etc. What you have to do is get one of the higher quality modules that use Bluetooth w/ wifi and connect to the wifi aspect of it with your Iwhatever. According to Google you have to do these steps with the Bluetooth w/ wifi adapters
So as you can see, the cheap adapter you have will not work with any Apple products. Apple has become the new Microsoft and only its products are allowed to work with its products, You have to use its own software, Torque doesn't exist in the world of Apple so stick with the Android tablet and do it the right way. Use the Iphone as it should be used, a cheap imitation brick/paperweight.Connect the Bluetooth Module w/ wifi to your car.
- On your iOS device, in the Settings, chose to connect to a Wi-Fi network. My module is called “CLKDevices” but your mileage may vary. It should be relatively easy to find out which one it is unless you’re in a very Wi-Fi heavy area, in which case you can just drive a bit down the road and see what name hasn’t disappeared.
- Once connected to that Wi-Fi network, click the small blue arrow to go to the advanced settings for it. Set the IP Address to Static. Configure the IP address to 192.168.0.123 and the Subnet Mask to 255.255.255.0. Then, go back and exit the settings. Other guides/videos might tell you to configure an IP as a “router”. That is not only useless but annoying as it would mean your iPhone would attempt to join the Internet through your module and any data would not come through as it’s connected to your car. Don’t set a router.
- Start your car. The OBD-II port was providing power to the module but in some cases you will not be able to retrieve any data from it if the car is not started.
- In your App, configure the connection to use a custom TCP connection with IP 192.168.0.10 and TCP Port 35000.
- Enjoy reading all this information on your car better and cheaper than by using the crappy scanners they sell in stores.
Hope this sheds some light on the subject.![]()
