Thread: Question on XP cam
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #1 Re: Question on XP cam
    GTX Level Member crbquist's Avatar
    Massachusetts
    As others have stated, you need to run at least 105 springs with that cam. You can run a new stock timing chain/dampener also, but you should raise the idle to prolong chain/dampener life. Some say 130 springs are the way to go in order to take full advantage of the xp's high rpm power, but 105's will be fine unless you want to squeeze every last bit of hp out of it.
    You may also want to consider the s1x cam. It is very similar to the XP, just slightly smaller with more low/mid range power. I have run it for two years and I love it. It's a great street cam. IMO, the s1x is even more friendly to a stock chain setup with 105's than the XP...
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Question on XP cam
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Already have my parts fellas, just lookin at what to expect from it.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
