Thread: engine vibrate on idle ?!?
Results 1 to 8 of 8
  1. #1 engine vibrate on idle ?!?
    Aug 2012
    Tukwila, Washington, United States
    recently when i idle it feels like my engine is shaking a bit, feels like random vibrates.
    when i rev/drive it stops.
    its starting to go bad everyday. and i don't have experience with this kinda thing.
    before it started i couldn't even feel im in the car now i get these random vibrations (no sound though).
    today i was about to park my car and the rpm went down almost to 200 and then back up to 1500 and 800.
    recently changed o2 sensor cleaned maf and changed pcv valve.
    for some reason i don't really feel its the engine mount since when i drive there's no vibration.
    An other thing is, when the car rev up and down the lights almost go off.
    I tried disconnecting the maf and when the rev needle went up and down the lights almost off.
    Could it be battery causing the car shake?
    im not sure how to start look for the problem cz its something you feel and maybe someone new that will drive the car wont notice so much.
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: engine vibrate on idle ?!?
    Sep 2011
    Arkansas
    IAC... idle air control I think? Could be wrong, but it sounds like what happened to me. Cheap part.
    Sent from my A200 using Tapatalk 4
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #3 engine vibrate on idle ?!?
    Aug 2012
    Can it be a low battery?
    Or alternator?
    It feels like almost a misfiring but I have new plugs.
  4. #4 Re: engine vibrate on idle ?!?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Quote Originally Posted by raverockstar View Post
    Or alternator?
    New plugs doesn't necessarily mean something isn't misfiring. Get it checked out if you can't figure it out.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  5. #5 Re: engine vibrate on idle ?!?
    St. Louis
    Irridium or copper plugs I hope?
  6. #6 Re: engine vibrate on idle ?!?
    Aug 2012
    Iridium plugs.
    And I kinda think its voltage.
    Battery was changed last year.
    But some weird things like my window roll up slower. Or lights dimming and rpm goes up and down.
  7. #7 Re: engine vibrate on idle ?!?
    Donating Users
    Aug 2013
    Michigan, USA
    Check ground hookup from battery to the chassis. Odds are it's corroded and making poor contact.
  8. #8 Re: engine vibrate on idle ?!?
    Aug 2012
    I think I figured what causing this vibration.
    Just instruct me what to do.
    It only happens when RPM gets very low.
    Let's say I turn the engine fans on and rpm goes up a bit so the car is ok.
    Maybe it's a throttle position or something?
  1. Low engine vacuum at idle after engine rebuild
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2013, 11:51 PM
  2. Front end shake/vibrate please help
    By cbcollins in forum Introductions/Noob Questions
    Last Post: 07-01-2011, 07:03 AM
  3. Engine returns to idle
    By tuchek in forum General Tech Discussion
    Last Post: 07-23-2010, 09:45 PM
  4. 97 gtp vibrate/rumble..
    By foogie in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2009, 07:58 PM
  5. engine will not idle
    By SCGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2009, 06:00 PM
