Thread: Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
Results 1 to 20 of 39
  1. #1 Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    GT Level Member JessicaRebel's Avatar
    Jun 2011
    So.Cal: Victorville/Adelanto
    Went to go to the gas station tonight and when i turned the car on the low coolant light started flashing. It hasn't done that at all today. It is always kept filled. I just had the ac compressor fixed yesterday. I opened the coolant reservoir and there is this... brown stuff in it and it looks like it is sitting on top of the green coolant. There are little bubbles and you can see the green under them. Anyone have any idea what it is? I have never had this problem before. My radiator does have a small itty bitty leak. I know they are not the best pics but I am trying to figure out if it is oil or possibly rust or god knows what. The pic of the paper towel on the tip is what it soaked up from the reservoir tank. And sorry the pics are not the best, took them on my cell. I checked the radiator cap and on the underside of it seemed to be oil. Could the place i took it for repair screwed it up when changing out my ac compressor somehow? The car is a 2000 pontiac grand prix GT. I am at a complete loss
    GPs eat sockets as Cookie Monster eats cookies.
  2. #2 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    St. Louis
    Looks like Dexsludge. The air is reacting with the Dexcool coolant and turning brown. Need to take care of that leak and flush the cooling system. Depending on what year of your GP it may also be time to replace the LIM gaskets. The low coolant light flashing is probably due to the sensor being coated in this junk. When you go to flush the system remove the coolany level sensor ( near the battery) clean it up and reinstall. Once you take care of the leak and get the coolant clean the light should go out.
  3. #3 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    The GP is a 2000. I have always put in green coolant so not sure if it would be dexsluge. I have been putting green in it since i bought it in 2011 but I am not sure what the previous owners put in. I hope i haven't been mixing it this whole time if it is dexsludge :/
    Also I forgot, when I checked the radiator itself, it was plum full of green coolant. Whatever this is, it seems to be sitting on top of the coolant in the reservoir tank only. And in the some of the pictures you can kind of see where there are like air bubbles and see the green under it.
  4. #4 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    Went to check it this morning and start it, there is a white exhaust coming out of the driver side tip, not a lot but it wrecks of gas. And forgot the cars SES light prior has been coming on and off did it like... eh 2 times trhowing a P0404- Exhaust gas re circulation Circuit range/performance. Not sure that has anything to remotley to do with this or even what the SES light is going to read now as that was from maybe like a week or more ago.
  5. #5 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Dexcool.
    If your rad is fine and the storage isn't, junk it and buy a new one from ZZP or another vendor (around $40). The storage tank comes off easily, two 10mm bolts on top hold it in place and just pull the hose out where it connects near the radiator cap.
    There isn't any real chance of salvaging it at this point. Flush the entire system to be sure, run conventional green from now on, and never look back. (See the link in my sig, the pic.)
  6. #6 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    I will end up having to get it towed just to flush it and change it out since I live in an apartment complex and honestly don't want to even drive it because it doesn't even sound right and with the little bit of white exhaust coming from the muffler and the god nasty gas smell that comes with it.
  7. #7 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    New coolant tank at the dealership is like $15
  8. #8 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    So it seems to be a coolant issue then. I could deal with it just being a coolant tank issue. Would there be the possibility of a blown head gasket?
  9. #9 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by JessicaRebel View Post
    burning coolant almost smells sweet, check your oil dip stick make sure your oil looks good, could pull plugs to see if one is not like the others,
    probly dex cool
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  10. #10 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    open the rad and see if the cap is full of brown snot. then top it off from the rad, not the over flow tank.
    looks like dex sludge to me, a coolant flush should fix it all. dont think the tow truck is needed. tell them to put green coolant in there.
  11. #11 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    I will go out and check it, I know last night the rad. was completely full of green coolant. The oil is dirty and low but it needs an oil change that was supposed to be done today. It's what I call its typical low from being driven. Ill pull the plugs to see if they are good or if one isn't like the others.
    It does not pay to live in an apartment complex, cant do anything here. Ill be back with results.
  12. #12 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    i hear ya on apt living, it sucks for doing repairs. im always at my friends house doing work, or in a public parking lot lol ive done a lot of work in the stop and shop lot here by me, p/s pump, brakes, tune up and the list goes on lol
  13. #13 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    Yeah it does almost everything car related has to be done somewhere else lol.
    So I looked there is no brown snot on it, just what looks to be black crust, it smelt like oil
    Inside the Rad. there seemed to be a little bit of brown right on the inside like right above the coolant but not much at all. cant really see it in the pic but i mean the coolant is bright and green. Like it should be
    On this paper towel the little bit of brown is what wiped off ( from what i mentioned above about the brown stuff.) The black is from the cap, and from trying ti wipe the inside of the rad
  14. #14 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    that all looks fine to me. the low coolant sensor on the rad maybe dirty and need a cleaning. when dirty they will make the low coolant light flash.
  15. #15 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    Ah ok I will have to get that cleaned. Would this cause the car to puff out the tiny bit of white exhaust i mean it almost looks like steam but smells to high heaven of gas, you would think I was dumping gas on the side of the car.
  16. #16 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    not sure on that. most cars will puff some steam out the pipes from left over condensation in the exhaust pipes. all cars get this, if you ever noticed a small puddle under your mufflers after idling parked for a bit. thats the condensation leaking out the pin holes that are in the mufflers. as the pipes heat up, the water burns off.
    if your smelling raw gas, id be looking for a leak somewhere.
  17. #17 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    it seemed to stop real quick after i let it run for like a min. so im guessing from the cold. I am wondering if the stop leak for radiators i put in it did this... gonna go flush it crossing my fingers lol
  18. #18 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    where was your coolant leak? id not worry about the stop leak unless your running hot.
  19. #19 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    Jun 2011
    Its a pin hole on the rad itself. We had put it in a month ago or so because it would leak out pretty bad it didn't over heat bad but enough to make it leak out once in a while
  20. #20 Re: Coolant reservoir has brown junk in it and low coolant light flashing. what is it
    id let it be for now. if it starts to leak again, its time for a new rad.
    stop leak aint always the best idea, some hate it, some dont think its all that bad. as long as your not over heating or running hot due to some kind of blockage you'll be fine.
  1. Flashing coolant light
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 07:07 PM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. flashing low coolant light.
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2011, 03:55 PM
  4. my low coolant light is flashing, any suggestions?
    By amy in forum General Tech Discussion
    Last Post: 08-21-2009, 11:23 AM
  5. low coolant light flashing
    By BrokenRhythm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:09 PM
