Thread: Getting vac line into engine bay
Results 1 to 7 of 7
  1. #1 Getting vac line into engine bay
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Is there any other way to get the vac line for a boost gauge into the engine bay without going through the passenger side firewall? I'd prefer not to make a huge detour.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  2. #2 Re: Getting vac line into engine bay
    You can poke a really small hole in the rubber where the steering shaft goes through the firewall and fish the line through there.
    Once through, go straight up with it and to the where you want it, use a zip tie or something to keep it tight against the firewall.
  3. #3 Re: Getting vac line into engine bay
    Aug 2012
    You can poke a really small hole in the rubber where the steering shaft goes through the firewall and fish the line through there.Once through, go straight up with it and to the where you want it, use a zip tie or something to keep it tight against the firewall.
    Thank you! Sounds like a good idea!
  4. #4 Re: Getting vac line into engine bay
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    If you T into the vac line under the supercharger snout, it's really not that big of a detour.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  5. #5 Re: Getting vac line into engine bay
    Quote Originally Posted by JaredR215 View Post
    its done already, and he took none of this info. and rigged it like no one should. lol i had to. as we all told you what to do and you did it the lazy mans way.
  6. #6 Re: Getting vac line into engine bay
    Lmao
    04 Comp G.
  7. #7 Re: Getting vac line into engine bay
    Aug 2012
    It works. It's not a show car anyway. And it's not a hard fix. Who cares?
  1. Help me ID this line/tube/wire in the engine bay...?
    By Bjm5295 in forum General Tech Discussion
    Last Post: 12-19-2012, 01:07 AM
  2. Engine Wire Harness/Fuel line
    By Spartan GL in forum General Tech Discussion
    Last Post: 04-27-2011, 07:17 PM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. AUX / Line In ?
    By vonlupe in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2010, 03:32 AM
  5. where does this vac line go?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 01:40 PM
