Thread: Lost and Confused: Temperature Gauge Issue
Results 1 to 14 of 14
  1. #1 Lost and Confused: Temperature Gauge Issue
    GT Level Member wyrmscar's Avatar
    Jan 2012
    Orlando, Florida
    So this morning on the drive to school my car decided to start acting up. I have no clue of what is going on other than to tell you to watch the video below. All I'm thinking is is going on. Car is not overheating.... And its doing it randomly. Someone care to take a crack at what the issue is and what would cause it?
    I Hump things for fun. Otto the Grand prix... Stupidcharged with bolt ons and stuff.
  2. #2 Re: Lost and Confused: Temperature Gauge Issue
    HUDSON
    That is caused by either a faulty ECT sensor, or a wire short. I had the exact same issue not too long ago, it was the ECT sensor. I Replaced it with one from O'Rieleys and the gauge actually reads accurate now.
  3. #3 Re: Lost and Confused: Temperature Gauge Issue
    Jan 2012
    Orlando, Florida
    Sooo what your saying is this:
    Buy Delphi Engine Coolant Temperature Sensor TS10032 at Advance Auto Parts
    Not having a proper temperature is really scaring me into thinking my motor could be overheating at any second.
  4. #4 Re: Lost and Confused: Temperature Gauge Issue
    Pennsylvania, USA
    My ECT was doing the same thing for a long time, it always said the car was running too cool. Replaced the sensor and now it's accurate. It's a cheap and easy fix, I'd just pop a new one in and see what happens.
  5. #5 Re: Lost and Confused: Temperature Gauge Issue
    Jan 2012
    Orlando, Florida
    Quote Originally Posted by nik12937 View Post
    spoke to a few other members about it... And thats exactly what im going to do lol.
    now that you mention it.... I think its been wrong since i have owned it!!! Its always said it was cooler than believable. But now it may have finally went faulty.
  6. #6 Re: Lost and Confused: Temperature Gauge Issue
    Cambridge, Ontario Canada
    You got a wet vac? You got Dex Cook in there?
    2005 E55 - stock
  7. #7 Re: Lost and Confused: Temperature Gauge Issue
    Jan 2012
    Orlando, Florida
  8. #8 Re: Lost and Confused: Temperature Gauge Issue
    Jan 2012
    Orlando, Florida
    Sooo replaced temp sensor... New one is even worse, just rose and stayed at 260 instantly.
    BUT i found a new melted wire upon further inspection... Please help(im desperately lost further) identify it and if its even related. It was spliced above the the sensor wire connection and connected into the block under the coil pack. see pics below:
  9. #9 Re: Lost and Confused: Temperature Gauge Issue
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Very common issue with these cars.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  10. #10 Re: Lost and Confused: Temperature Gauge Issue
    in this pic the wire in your hand, and the yellow wire on that plug connector is also cracked, those bare wires are your problems.
    where wa the wire in your hand plugged in? thats not a factory end at all.
  11. #11 Re: Lost and Confused: Temperature Gauge Issue
    oh, pretty sure that plug with yellow broken wire is to the temp sensor, its a 5 inch pig tail from a plug to the sensor.
  12. #12 Re: Lost and Confused: Temperature Gauge Issue
    Jan 2012
    Orlando, Florida
    yes you are correct sir! That yellow wire connected to the broken plug that you seen in my friends hand. It was connected into the spliced(broken as you said so) wire By a female red piece that snapped off. it connected to were the wire was broken and then the male( the yellow wire) plugged into it right before sensor.
    Solution proposal...
    1.Go to junkyard and get a new set of wires that connect to the sensor...
    2. Cut the ones at the junkyard a bit before the connector
    3. Take both new connectors and a new plug.
    4. get it home and connect by most likely solder with proper wrapping.
    How does that sound to you?
  13. #13 Re: Lost and Confused: Temperature Gauge Issue
    id just hit a JY and cut that plug off another car, leave it as long as you can 4 to 5 inches is good, then solder and shrink tube it.
    http://www.grandprixforums.net/how-p...ent-73671.html
  14. #14 Re: Lost and Confused: Temperature Gauge Issue
    Jan 2012
    Orlando, Florida
    Sweet thanks as usual scotty! You just summed up my idea! And i agree... Shrink tubing is the way to go!
  1. Temperature gauge reading hot!
    By gloryabides in forum General Grand Prix Discussion
    Last Post: 01-10-2013, 10:31 PM
  2. Lost and Confused
    By Max Wood in forum Introductions/Noob Questions
    Last Post: 09-06-2012, 01:51 PM
  3. Temperature/AC issue
    By Mconner in forum General Tech Discussion
    Last Post: 06-16-2012, 11:09 AM
  4. Help With Temperature Gauge issue!
    By gcschi22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2011, 10:55 AM
  5. Erratic Temperature Gauge..HELP PLEASE!
    By gtpgrl2000 in forum General Tech Discussion
    Last Post: 08-12-2010, 05:50 PM
