Thread: Few simple questions
Results 1 to 11 of 11
  1. #1 Few simple questions
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So I just completed my top swap a few days ago and have a few questions.
    1. For my boost/vacuum gauge, how much vacuum pressure is normal to see? I am seeing about 7psi at most and was wondering if that is normal or if I have a leak.
    2. I am currently running 3 pounds of boost and have no KR. How much more boost do you think it would be safe to run on a 04 gp with headers, HAI, 180 t-stat, and 3.5" pulley?
    3. My s/c sounds kinda like a waterfall. I am going to search for what I need to do to fix that because I remember seeing a thread about it but if I dont post anything about finding it then some advice with it would be nice. Thanks in advance,
    Mike
  2. #2 Re: Few simple questions
    You should be seeing atleast -19 to -20in/hgs of vacuum.
  3. #3 Re: Few simple questions
    Oct 2011
    huntley
    Ok so I have a huge vacuum leak. I will look at it tomorrow to see where it is and try to fix that. Any answers for the other questions?
  4. #4 Re: Few simple questions
    GT Level Member atj8's Avatar
    Midwest
    you should definitely get more than 3 lbs of boost with that set up..
  5. #5 Re: Few simple questions
    Oct 2011
    huntley
    I had my dads friend who is a mechanic put this all on with some of my help and he said that I think he took off the boost sensor or something like that so to get more or less boost I need to loosen these two screws and adjust a cylinder looking thing(if I remember the correct shape) and he just had it set for 3psi cause he didnt know how much to set it to
  6. #6 Re: Few simple questions
    Is the bbv setup to run off strictly vacuum? Do you have it tuned?
  7. #7 Re: Few simple questions
    Oct 2011
    huntley
    Its is tuned by zzp with there How would I know if the bbv is set to strictly run off of vacuum?
  8. #8 Re: Few simple questions
    Oct 2011
    huntley
    So my boost/vacuum gauge reads -7in/hg of vacuum and my aeroforce reads -9.5. I tried spraying starting fluid by my vacuum connections and I didn't hear any difference in my engine idle. Any other ways to check for vacuum leaks?
  9. #9 Re: Few simple questions
    Dec 2012
    troll land
    Put your hand over the tb if it idles up or doesnt change at all its a vac leak
  10. #10 Re: Few simple questions
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by hockeybawler View Post
    Yeah the best way you can check for vaccum/evap leaks is with a smoke machine. Unfortunatly they are around 1k plus dollars. I modified a 50 dollar Halloween smoke machine to use on my own vehicles..... not really sure if Halloween fog is good for your engine but Ive found some hard to find leaks with it more than once....
    I went NA when a whore left -$300 in my bank account.
  11. #11 Re: Few simple questions
    Oct 2011
    huntley
    I saw something about that when searching about vac leaks, how did you make yours?
  1. probably a very simple probblem
    By 2004GrandPrixGT1 in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2012, 12:01 AM
  2. Speaker Upgrade! Need a few simple questions answered please!
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2012, 07:20 PM
  3. simple question
    By Below Average Joe in forum General Tech Discussion
    Last Post: 10-18-2011, 12:32 PM
  4. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  5. have some simple questions
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2008, 09:59 PM
