Thread: Maintenance help!
Results 1 to 16 of 16
  1. #1 Maintenance help!
    Apr 2013
    White Lake
    I have a few questions and some advise needed!
    2005 Grand Prix GT 117k Miles
    Bought the car with 113k Miles
    So far I've done
    All new Rotors
    All new Brakes
    Oil Change done twice so far "Valvoline"
    New AC Delco Wires/Plugs 41-101
    PCV Valve
    Radiator Flush
    Plastic Elbows "which caused all new fluid to come out"...
    Back Drivers side wheel hub bearing.
    Next I want to do a transmission change which means I just want to drop the pan, drain, put new filter, fill with new fluid. I know it should be done every 100k so would I still be okay? I read thread on here and it kinda freaks me the "F" out =/
    My Serpentine Belt looks fine and not sure if that was ever replaced so should I go ahead and replace it anyways?
    Also how do you check if your suspension is bad? When I drive the car I can feel vibration from the steering wheel which isn't to bad until I drive on the express way and then you can really notice the vibration. I'm not really sure what to look for if something is bad or broken.
    Anything else that i should know of or do to help make my vehicle have a long wonderful life?
    Thanks! =D
  2. #2 Re: Maintenance help!
    Do a pan drop and filter change you won't hurt anything. Jack the car up and try to wiggle the wheel and see if anything is loose
  3. #3 Re: Maintenance help!
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    Check half-shafts and if you ever get them replaced don't go "cheap"
  4. #4 Re: Maintenance help!
    Max Cook
    Guest
    ^this
    I wouldn't worry about the belt unless it looks like hell until it starts squealing or snaps, but theyre not overly expensive or difficult so yeah.. I would change the fluid on the tranny more than every 100k. I change mine every 20k, of course im a lot harder on it than a stock car is. Just don't flush it, thats where you run into major issues. pan drop + filter change is fine.
  5. #5 Re: Maintenance help!
    X1000 on doing just a pan drop. Hell you can get the Dorman trans pan and make it easier on yourself to drain the fluid in the future through the plug.
    04 Comp G.
  6. #6 Re: Maintenance help!
    Jun 2013
    Hollywood ,FL
    do they make the dormans for an 05 gtp dont gtp have the hd tranny? how much is the pan
  7. #7 Re: Maintenance help!
    The pan is the same for all 98+ grand prix
  8. #8 Re: Maintenance help!
    Apr 2013
    White Lake
    Where can I find this pan at, link? Also when I change the trans fluid how often should I change it again?
    Also anything else I should look into other then what I said to help keep my GP living strong?
    Thanks!
  9. #9 Re: Maintenance help!
    Dorman #265-814 just makes it easier to drain in the future.
    04 Comp G.
  10. #10 Re: Maintenance help!
    Wouldn't hurt to change the fuel filter either.
    Also throw in a shift kit when you do the pan.
    Transgo SK4T65E Shift Kitl
    http://www.grandprixforums.net/diy-h...res-79486.html
    Very detailed write up
    04 Comp G.
  11. #11 Re: Maintenance help!
    Apr 2013
    White Lake
    Alright thanks a bunch! Right now all my money has been going towards my dirt bike but after I will get right on this!
  12. #12 Re: Maintenance help!
    Apr 2013
    White Lake
    So I took my car of to my parents house to have my dad check on my suspension and while he was looking he noticed 3 out of 4 tire weights were missing, would this cause vibration?
  13. #13 Re: Maintenance help!
    Feb 2013
    37.295091, -121.930053
    Ummmm YES!!!!!!!
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  14. #14 Re: Maintenance help!
    it sure could. best to take the car to a tire shop, have them balance and rotate the tires.
  15. #15 Re: Maintenance help!
    This. Will make all the difference most of the time.
    04 Comp G.
  16. #16 Re: Maintenance help!
    Apr 2013
    White Lake
    Alright will get them balanced and rotated! i'll let you guys know if it fixes the problem!
  1. 75k Maintenance?
    By develand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 01:47 PM
  2. Doing some maintenance
    By GoldGTP in forum General Tech Discussion
    Last Post: 03-17-2011, 01:39 PM
  3. car maintenance
    By cerick08GP in forum Off Topic Discussion
    Last Post: 11-29-2010, 02:33 AM
  4. maintenance fun
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 12:21 AM
  5. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
