Thread: How to remove shifter linkage?
Results 1 to 2 of 2
  1. #1 How to remove shifter linkage?
    Jun 2012
    Southern NJ
    I unbolted the shifter, but I can't see how you detach the shifter linkage from it.
  2. #2 Re: How to remove shifter linkage?
    work the shiftier back and fourth the end of the rod should be in line with the cable, move it till you see the pin or clip that holds it to the shiftier.
  1. shift linkage issue
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2010, 02:14 AM
  2. Steering Linkage!
    By blckgtp in forum General Tech Discussion
    Last Post: 05-31-2009, 03:34 AM
  3. Shifter button stuck?? Cant remove key
    By PRIXSY in forum General Tech Discussion
    Last Post: 02-25-2009, 07:45 PM
  4. Trans linkage stiff???? Need help!!!
    By drums4life0922 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2008, 11:25 AM
  5. Shifter Linkage
    By J_Ferguson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2008, 01:57 PM
