Thread: Hole size for sensor
Results 1 to 3 of 3
  1. #1 Hole size for sensor
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Doing the diy intake on my car and I need to know what size bit to use to give the sensor a snug fit. Thanks!
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  2. #2 Re: Hole size for sensor
    what i did was to stick the drill side ( the smooth side) of my drill bits into the stock air tube ait sensor hole till i found one that was the right size.
    then once it was painted and dry i used a small bead of gorilla glue to secure it in the pipe. rtv would also work. use a smal amount as you dont want to see it.
  3. #3 Re: Hole size for sensor
    Aug 2012
    Thanks!
  1. Lower control arm mount hole size
    By stingray355 in forum General Tech Discussion
    Last Post: 06-20-2013, 10:08 AM
  2. Hole In Header :-(
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2012, 10:36 AM
  3. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  4. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  5. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
