Thread: what paint to use on intake
Results 1 to 13 of 13
  1. #1 what paint to use on intake
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Going to be doing a diy intake. What kind of paint should I use on the pvc?
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  2. #2 Re: what paint to use on intake
    Dec 2012
    Where 4T65E's were born
    Any high heat enamel should do. Like up to 500°F.
    Sold.
  3. #3 Re: what paint to use on intake
    new britain, ct
    yeah...go to autozone and they sell a bunch of VHT engine enamel paint.
    you can use that on other things if you want too.
    07 Black GXP.
  4. #4 Re: what paint to use on intake
    i used rustolium black gloss paint, its still on there.
  5. #5 Re: what paint to use on intake
  6. #6 Re: what paint to use on intake
    Aug 2012
    why the "..."? lol
  7. #7 Re: what paint to use on intake
    it's an intake. what does it get, 120* max? you don't need high temp paint.
  8. #8 Re: what paint to use on intake
    Oct 2012
    Nowhere NY
    i used reg gloss rustoleum on mine, looks fine
    Ive been medicating with burnouts and alcohol
  9. #9 Re: what paint to use on intake
    Dec 2012
    Yeah you're probably right, but I'd still use engine enamel for the piece of mind and the fact that it's really not any more expensive.
    If you have regular spray paint already just use that.
    Sold.
  10. #10 Re: what paint to use on intake
    Aug 2012
    That was the plan. Already have paint to use!
  11. #11 Re: what paint to use on intake
    Dec 2012
    Oh, and when spraying PVC piping you should sand it with a fine grit sandpaper first. It doesn't stick well to the smooth finish of pvc.
    Sold.
  12. #12 Re: what paint to use on intake
    Pennsylvania, USA
    I just used some low gloss black from Advance Auto, not high temp or anything, and about half a year later it's fine. Probably better off with a high temp since our engine bays heat soak so bad, but it's not necessary.
  13. #13 Re: what paint to use on intake
    Dec 2012
    I wonder if having headers as well as being in a hot climate is enough to use it
    Sold.
  1. Replies: 6
    Last Post: 07-02-2012, 07:01 PM
  2. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  3. Fascia paint! and caliper paint!
    By GAFF in forum Visual/Body Modifications
    Last Post: 08-18-2010, 12:15 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
