Thread: Windows wont go up or down
Results 1 to 7 of 7
  1. #1 Windows wont go up or down
    Jul 2013
    canada
    I am having trouble with my passenger side windows front a back neither window will go up or down from either driver side button or from passenger side buttons. All other windows work fine, I have swapped the rear drivers side button with passenger side in rear and still don't work. THey both seem to be getting power when tested them could both motors have went at same time seems wierd but hey i have seen some weird **** happen before lol. I have also grounded the brown wire and hook blue wire to battery and still get nothing to passenger side front. Would not be so bad if it would have been one window but both at same time on same side weird. Any one got any ideas?
  2. #2 Re: Windows wont go up or down
    test for power at the plug end where it would plug into the window motor, work the switch, see if its sending power.
  3. #3 Re: Windows wont go up or down
    Jul 2013
    canada
    the switch is sending power out of the the back but get nothing no up or down. when i jumped the front one i would get a click from the motor i think i could here it not nothing else.
  4. #4 Re: Windows wont go up or down
    if your running power right to the motors from the battery, make sure it got a good ground as well, and they dont move at all, it looks like the motors both crapped out.
    as long as theres power at the plugs when working the switch, the motors should be the problem.
  5. #5 Re: Windows wont go up or down
    http://www.grandprixforums.net/weird...ml#post1083021 crazy as it sounds, this guy had the same problem as you.
  6. #6 Re: Windows wont go up or down
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Just like scotty said, the motors probably took a dump on you. It's common. I have a buddy and he has a 4 door gtp. 3 of the windows don't work lol. It's absolutely ridiculous. Good luck, it's probably going to be the motors though, shouldn't be too pricey. Glad I have a coupe, that's half the amount of windows that can stop working! but good luck man
  7. #7 Re: Windows wont go up or down
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by goon View Post
    goon--
    It's more than likely the window motor. I had two window motors crap out at inopportune times, both within a month of each other. Just replace the window motor and regulator, a new one runs you about $90 at AutoZone and comes with a lifetime warranty. It's not too difficult to replace. Ideally you want a T-25 torx bit, but I found a 3/16 allen wrench works, too. That, and a 10mm socket and you'll have it replaced in an hour or less.
    Just be glad yours didn't get stuck in the "down" position with a storm front bearing down on you. Talk about a fix done under pressure (I finished about 10 minutes before the heavens opened up).
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  1. Replies: 5
    Last Post: 07-02-2013, 06:14 AM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. My windows wont work.... HELP is appreciated
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-16-2013, 11:30 PM
  4. Windows Wont Roll Up or Down
    By MustangMatt96GT in forum General Tech Discussion
    Last Post: 07-11-2011, 06:16 PM
  5. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
