Thread: How to remove left-side dogbone bracket
Results 1 to 9 of 9
  1. #1 How to remove left-side dogbone bracket
    Jun 2012
    Southern NJ
    How do you remove the dog-bone bracket on the head on the left side? The one on the right is pretty straightforward, but I've removed two bolts from the left one and it won't budge.
  2. #2 Re: How to remove left-side dogbone bracket
    The Boss Iceman6669's Avatar
    Jun 2011
    there is 3 bolts.. 2 bolts and the tensioner
    2011 F-150 Yote powered
  3. #3 Re: How to remove left-side dogbone bracket
    Jun 2012
    Southern NJ
    Quote Originally Posted by Iceman6669 View Post
    Alright, thanks dude.
  4. #4 Re: How to remove left-side dogbone bracket
    the icm harness has a 8 mm bolt iirc that holds the plug on, and the tensioner needs to also come off. there is also a black ground wire from the icm, its bolted down with the bracket, dont forget to hook it back up.
    you'll need a deep 13 mm, a shallow 15 mm, and a 15 mm wrench and a 8 mm socket.
  5. #5 Re: How to remove left-side dogbone bracket
    Jun 2012
    Southern NJ
    I may or may not have winged it with a series of adjustable wrenches, vise grips, and other tools.
    Let's just say it's off of there now.
  6. #6 Re: How to remove left-side dogbone bracket
    I like the part that you didn't tell us which of the two available brackets you have.
    Do you have cast iron or aluminum?
  7. #7 Re: How to remove left-side dogbone bracket
    Jun 2012
    Southern NJ
    These bastards are nice and heavy, so I'm gonna go with cast iron, but it doesn't matter since they're both off and the head is off the car now.
    Thanks for the response, though.
  8. #8 Re: How to remove left-side dogbone bracket
    Well.. the passenger side is one of the two..and the aluminum isn't heavy, however the driverside one is aluminum and light.
  9. #9 Re: How to remove left-side dogbone bracket
    Jun 2012
    Southern NJ
    Look Bill, I'm not some fancy metal scientist. I'll leave this one up the people who actually know what they're doing.
  1. 01 GP drivers side headlight bracket
    By KoldAsIce in forum Brakes/Suspension/Chassis
    Last Post: 03-10-2013, 10:13 PM
  2. How Do I Remove the Left Quarter Panel?
    By y1a3o in forum Off Topic Discussion
    Last Post: 05-12-2008, 01:24 PM
