Thread: k&N filter yes or no?
Results 1 to 20 of 23
  1. #1 k&N filter yes or no?
    Aug 2013
    NY
    Is a K&N air filter worth the money?
  2. #2 Re: k&N filter yes or no?
    No.
    Doesn't filter air as well as a paper filter, which is the #1 job of the air filter.
  3. #3 Re: k&N filter yes or no?
    Mar 2013
    Spring, TX
    Just no.. If you want to do something intake related though there are multiple threads about "Home Depot Intakes". Basically a Spectre cone from Auto Zone and some PVC from Home Depot. It works just as well if not better than a K&N CAI for a fraction of the price..
  4. #4 Re: k&N filter yes or no?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Do it yourself intake. That is all.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  5. #5 Re: k&N filter yes or no?
    Quote Originally Posted by AceGTP View Post
    Quote Originally Posted by ILoveGM View Post
    OP asked about the filter, not the intake. :\
  6. #6 Re: k&N filter yes or no?
    Banned
    Jan 2013
    Colorado
    Yes, try breathing through a piece of paper then your shirt. Plus it never needs to be replaced. Just cleaned.
  7. #7 Re: k&N filter yes or no?
    Quote Originally Posted by camopaint0707 View Post
    Measure the restrictions in your intake before jumping to conclusions.
    The point of an air filter is to filter.
    If you're fine having your valve seats and rings wear quicker, by all means. If you're not, do some homework first. Don't just do something because the internet or a company who sells the product says so.
  8. #8 Re: k&N filter yes or no?
    Banned
    Jan 2013
    Colorado
    I didn't say anything that was quantifiable. I said try breathing through a piece of paper and then a t shirt. I suggest you do some research before jumping to conclusions.
  9. #9 Re: k&N filter yes or no?
    A paper filter isnt like a real piece of paper, looooooooooooool.
  10. #10 Re: k&N filter yes or no?
    Dec 2012
    troll land
    Get one worth it and wont fall apart like a spectre
  11. #11 Re: k&N filter yes or no?
    Dec 2012
    troll land
    I guess every engine ive owned has had worn out valve seats then huh?
  12. #12 Re: k&N filter yes or no?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    250k miles with 150k being K&N filtered valve seats, cylinder cross hatching compression and everything were all just fine. They filter well enough, but the idea of flow vs filtration is a give and take thing things that flow better can't filter better, think of a screen door, it will flow great but won't filter much, while a steel plate will filter out everything including the air.
  13. #13 Re: k&N filter yes or no?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I use a K&N. You could probably read a book through it while holding it up to the light. So I don't recommend them, unless you use an oiled foam pre-filter - which would probably then do most of the filtering.
    Take a look at some factual information:
    K&N Air Filter Review - Debunking the Myths (and why OEM is better)
  14. #14 Re: k&N filter yes or no?
    I live here. TLSheff's Avatar
    To be fair, the ZR1 corvette makes how much horsepower? Uses a stock ACDelco paper filter... not a K&N.
    Just sayin.
  15. #15 Re: k&N filter yes or no?
    Dec 2012
    troll land
    And how much does that same vette make with a k&n anyway if ur that worried about slightly shortening engine life leave ur car bone stock since addin hp wears ur bearings out faster
  16. #16 Re: k&N filter yes or no?
    Dec 2012
    troll land
    Lmfao your actual "fact" link about how oem is better is a reportbased off an OEM TEST?! lol hav fun n a prius
  17. #17 Re: k&N filter yes or no?
    This is seriously a debate? Use whatever the f you want.
    04 Comp G.
  18. #18 Re: k&N filter yes or no?
    Quote Originally Posted by l67ss View Post
    ummm... I'd assume less actually.
    So say'th the dyno anyways. But you never can trust those silly dyno machines.
    Air Filter Dyno Comparison - ZR1 OEM Element wins!!! - SmokinVette.com Forums
  19. #19 Re: k&N filter yes or no?
    Apr 2012
    Goderich, Ontario
    I've had my k&n filter for 4 years and no problems. Clean and re oil it once a year and forgot about it. The filter doesn't cost more then any other cone filter and your not gonna notice a difference in flow, hp, ect. Most of that is bs. Most people say there a waist of money and OEM is better yet a cone air filter is the first mod most people do. Doesn't make sense to me. If your thinking of buying a k&n filter than go buy one and enjoy it.
    -Paul Walker
  20. #20 Re: k&N filter yes or no?
    Most people usually jump to a CAI or FWI or Short Ram Intake, with a cone filter. But if you just change the filter and keep the stock box, a K&N filter won't do much of anything due to the restrictions in the stock tubing and air box.
  1. Air filter or CAI?
    By JDrach in forum General Tech Discussion
    Last Post: 11-25-2011, 12:48 AM
  2. kn filter on tb
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-27-2011, 10:40 AM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  4. Which oil filter?
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2009, 10:01 AM
