Thread: Problems
Results 1 to 6 of 6
  1. #1 Problems
    Aug 2013
    MINNESOTA
    My daughters cars a/c gets cold and then flux between warm and cold. Believe it may be the blend door actuator. If it only has one climate control does that mean I only have one actuator to locate? And would it be in the lower center or pass side of dash? Also if it does sound like the actuator, would it trip the engine light to stay on till fixed? Daughter think its code had something to do with air circulation. Still I have to check code at parts store. Just curious till then. Any help is appreciated.
  2. #2 Re: Problems
    I live here. TLSheff's Avatar
    Need a little more info on the car first.
    Year
    Trim
    PM me the last 8 of the vin # and I can get you a blown up view of the actuators for the AC system.
  3. #3 Re: Problems
    actuators cant set a code, have the car scanned again, see what the code is for.
    best bet for the a/c is to take the glove box off, and watch the actuators movement.
    heres the how to, http://www.grandprixforums.net/blend...ent-21941.html not sure if you have one or 2 of them, but when theres 2 they control the side they are on. so one side could be hot, and the other cold. if you take them off you can turn the little knob they control manually to hot or cold. as a test.
  4. #4 Re: Problems
    Aug 2013
    MINNESOTA
    Vin is 61299877. Also just told her tie rod end and wheel bearing needs to be replaced. Any special tools needed for this repair? And do I buy the expensive bearing and is it ABS? Thanks for the help and any tips are appreciated.
  5. #5 Re: Problems
    tie rods are easy, take the nut off the bottom, then hit the steering knuckle with a hammer where it bolts through. it will pop right out.
    the hub, you need a 36 mm socket, (for the axel nut) and a pipe or a air gun to get it off. the rest is normal hand tools.
  6. #6 Re: Problems
    Aug 2013
    MINNESOTA
    Thanks! Wish me luck
  1. Several Problems
    By kesey in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-14-2012, 05:58 AM
  2. HID problems :(
    By Hamnjelly in forum Visual/Body Modifications
    Last Post: 01-24-2012, 12:39 AM
  3. hid problems
    By jspangler22 in forum Visual/Body Modifications
    Last Post: 05-13-2011, 05:29 PM
  4. Problems
    By BThomp in forum Introductions/Noob Questions
    Last Post: 08-22-2010, 05:54 AM
  5. 07 gxp with nav mp3 problems
    By pjs29 in forum General Tech Discussion
    Last Post: 08-22-2009, 01:11 PM
