Thread: Daytime running lights problem
Results 1 to 3 of 3
  1. #1 Daytime running lights problem
    May 2012
    Ft.worth,Tx
    My lights stay on when the key is out of the ignition. I have to disconnect the battery to solve the problem. Is there any other solution? I have a 2007 grand prix.
  2. #2 Re: Daytime running lights problem
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Are they staying on indefinitely? How long have they been staying on? Have you checked the settings in the DIC under "Personal Programming Mode?
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  3. #3 Re: Daytime running lights problem
    May 2012
    Ft.worth,Tx
    Quote Originally Posted by Chadgervais View Post
    I found the solution on one of the posts. It was the drl relay. I replaced it and it solved the problem. Thanks to whoever posted that answer. I don't remember who it was. I thought at first that was the problem but I was not sure. About 2 years ago I had a problem with the low beams going out sometimes at night and later on they would come on. I was reading the posts in this forum and again somebody came up with the solution and it was the drl relay. It is #35 in the fuse box under the hood. I have replaced this fuse twice in the last 2 years. The good thing is that the relay has a lifetime warranty at Autozone. If I have to replace it again I think there might be a wiring problem somewhere.
  1. I need some help with my daytime running lights!!!!!!!!!
    By ReapeRx in forum Visual/Body Modifications
    Last Post: 07-25-2012, 06:03 PM
  2. Daytime Running Lights
    By joeringo11 in forum 04+ Specifics
    Last Post: 01-27-2012, 12:07 PM
  3. Daytime running lights
    By lucyboop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2011, 09:10 PM
  4. Daytime Running Lights at Night Problem
    By Ncosta in forum General Tech Discussion
    Last Post: 07-14-2010, 12:36 PM
  5. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
