Thread: Is this why i can't use my shifter?
Results 1 to 17 of 17
  1. #1 Is this why i can't use my shifter?
    Dec 2010
    DMV
    Ok can't use the shifter without pressing the shift lock switch. Did some digging and found this
    Why is this cut smh. What exactly are these wires that have been cut?
    Sent from my HTC One using Tapatalk 2
  2. #2 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    Bump bump
  3. #3 Re: Is this why i can't use my shifter?
    Kansas
    What do you mean you can't shift without pressing the shift lock lever? Like from D-1? or from park to reverse to drive? And where are those wires located, and what year?
  4. #4 Re: Is this why i can't use my shifter?
    if those wires are in the console, that could be why its locked in park on you. look for a plug with cut wires where ever its located.
  5. #5 Re: Is this why i can't use my shifter?
    GTX Level Member crbquist's Avatar
    Massachusetts
    I had the same problem and the wires had to be soldered back together.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  6. #6 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    99 gtp in a 98 gt shell. Those wires are under the center console right by the shifter.
  7. #7 Re: Is this why i can't use my shifter?
    look at the shifter for the other end of those cut wires. or for where the plug should be.
  8. #8 Re: Is this why i can't use my shifter?
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    The plug for those should be on the base of the shift lever. It's kind of a pain to get it out, but I found shifting into 1 helps give you room to wiggle it out.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  9. #9 Re: Is this why i can't use my shifter?
    I'd hit a junker and grab the pigtail with about 4 inches of wiring. Reconnect and smile when your car works properly.
  10. #10 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    Funny story. I see no connector. Unless I'm super blind
  11. #11 Re: Is this why i can't use my shifter?
    Funny story.. your cars PO probably cut it and then sold it to you. You bought it effed up. Now go get it and fix it.
  12. #12 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    Well i can't be too mad for 500 bucks lol
  13. #13 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    finally found the connector. After looking again. Is there a way to connect to the wires to the connector again? I mean they are cut off at the base of the connector. Can u just pop the silver pieces out?
  14. #14 Re: Is this why i can't use my shifter?
    Sure..it's tough w/o the proper tool for pinning etc. Or you can do it the super quick and easy way I suggest.
    Your choice...Battle Royale or BillBoost method.
  15. #15 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    Junkyard here I come lol
  16. #16 Re: Is this why i can't use my shifter?
    Jun 2012
    Southern NJ
    You're already half-way to a fancy ratchet shifter. Rip out that garbage stock shifter and throw in a B&M Quicksilver.
  17. #17 Re: Is this why i can't use my shifter?
    Dec 2010
    DMV
    Fixed! Next issue here I come!
  1. Short Shifter [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2012, 10:23 AM
  2. shifter
    By 71dang in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-17-2011, 05:36 PM
  3. Shifter
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 05-17-2010, 07:02 PM
  4. Shifter does not light up
    By Jesse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2009, 10:23 PM
  5. shifter
    By justwhisen in forum Visual/Body Modifications
    Last Post: 08-07-2008, 07:23 AM
