Thread: 99 GT Tranny 4th gear gone
Results 1 to 4 of 4
  1. #1 99 GT Tranny 4th gear gone
    Mar 2013
    Kansas
    4th gear finally went out in my 99 n/a gt. I'm getting it rebuilt and want the chain ratio changed from 35/35 to 37/33 to get an overall ratio of 2.93. Anyone know how this will affect the economy of the car?
    99 Pontiac Grand Prix GT 3.8 N/A K&N CAI E3's
    "If you can't drive it like you stole it...sell it!"
  2. #2 Re: 99 GT Tranny 4th gear gone
    Yes..you will see lower rpm. You will need a pcm reprogram and maybe tweaks to keep it from bogging.
  3. #3 Re: 99 GT Tranny 4th gear gone
    Mar 2013
    Kansas
    What kind of tweaks?
  4. #4 Re: 99 GT Tranny 4th gear gone
    Well.. you are NA, so your motor isn't an all out power monster and your shift speeds are based on 3.29 gearing. This gearing keeps your rpm higher which means you'd have more power. By swapping the gearset you will lower rpm at those same speeds, this causes bogging because the motor wasn't designed to hold 4th gear uphill at 42mph at 1100 rpm. The motor simply doesn't have the power and it'll bog.
    You would want to tweak your shift points in order to allow a downshift earlier and or shift into gear at a slightly higher rpm.
  1. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  2. Tranny takes a while to shift into 2nd gear
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-19-2010, 01:57 AM
  3. Tranny shifts from 2nd gear to Overdrive?!?!?
    By atrainbynight in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2009, 04:14 PM
  4. Tranny knocks when shifted to gear
    By Viper in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 01-27-2009, 04:11 PM
  5. 97 Grand Prix GTP Tranny shifts into 2nd gear late
    By Reeddawgy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2008, 08:32 PM
