Well it's running well again. For now. I hope this one works.
Say worst case the wires were bad. I haven't found much info on replacing/repairing them. Any insight?
I'm having the same issue. New (not reman) borg warner maf from advance and I have P0102 and P0171. All factory aside from ZZP exhaust and hai.
I've read post after post of suggestions and tips for P0102, but none with any follow through saying, I did all of this and none of it worked. That's the answer I'm looking for![]()
cut the old plug off, strip the wires back till you hit clean shinny copper wire, then solder the new pig tail on. ( my maf wires were bad 2 inches from the main harness)
nothing else will last but solder and shrink tubes.
this is of course if you find cracks or missing insulation on the wires. once air gets to the copper wire it gets whats called dry wire. its tarnished copper, it no longer flows current properly and will set the low voltage code.
solder and shrink tubes will prevent dry wire, where tape will fail, and so will butt splice connectors. especially under the hood where they can get wet and hot.
