One possibility although not a good one, is that the engine may be developping Rod knock. It will usually happen at low load.
On one of my 160K miles turbo cars that I was running at very high boost daily (31 psi) I started to have rod knock that I could hear.
Before I could hear it I would get a lot of knock at RPMs and loads that I would never see any. Besides the car was tuned to perfection and would almost never get any KR.
The car was equiped with a knock warning system in the dash (Eagle Talon TSI AWD with DSMlink)
It could be anything from an extra sensive knock sensor (replace), a loose knock sensor, too tight knock sensor.
Bad wiring to knock sensor. Noisy anything in the engine, noise in the transmission/axles transferring vibrations to the knock sensor.
To me it sounds like you are not getting true knock. True knock rarely happens at part throttle low load. One sure way to find out, add more race fuel (50/50 C16 and 91) then test again.
You can always drain the tank and keep your 50/50 mix for racing later.
