Trying to decide honestly.... Leaning towards a 20 inch as I do not want to lose performance
Well, it was between 18 or 20 inches for me. 20 inches you lose minimal performance if any.. Width restrictions are exactly what you said. I do not want tires that "poke out" or take away from the car. I personally am leaning with wheel number one as well.. Just wanted to get more opinions...
Anyone know of a good web site to look at other wheel options?
the first wheel looks a little wide. what size does it come in? website?
depends on how much you want to spend as well. a GOOD set of wheels alone will set you back $2k+.
That first wheel is $1500 and it comes in a 9 inch width... It comes from a place called Hot Wheel City here in Detroit (http://hotwheelcity.com/)
actually looks like in 20s you can get them in 8.5", 9", 10.5", and 12" wide. they are called niche sportiva's.
both the 8.5" and 9" wheel come in a friendly +35mm offset, which is good for you.
the 8.5" is going to be 5x115, the 9" will be 5x114.3. both will work, but just to be specific so you're aware.
i like them and i think that either of those sizes would look good running a 245 wide tire.
@Bio248 I appreciate all the help sir! I think I am going to go with that wheel...
Love multi-spoke wheels, but yeah... #1 is definitely the better choice.
Sent from my A200 using Tapatalk 4
(Stock)
Stockers are the best of the 3, but if you are adamant about getting new wheels go with #1.
Keep your stock 18"s and lower it.
I like to look of #1 better, they might be easier to clean.
I went to hotwheelcity as well when I was first looking for rims. You can find a nice gently used set for around 7-800 tho on Craigslist. Maybe driven a season or so. As soon as you pull away from there the value just goes down so much to where idk if I'd spend 2 grand on rims. Is 1500 including tires?
You don't buy rims unless they're super cheap or high end if your thinking its going to maintain value. Plus most will rather just hit up Craigslist and spend $500 on curbed no name rims rather then buying from a well known company. Shrugs
