Thread: Deleted resonator, should i feel sluggish now?
Results 1 to 14 of 14
  1. #1 Deleted resonator, should i feel sluggish now?
    Nov 2012
    Bay City, MI
    It feels like i lost a lot of power in the low end, i can't hear my blower anymore, and its ****ing annoying.
    Should this have happened with a simple res delete? needless to say, the cat is going back on
  2. #2 Re: Deleted resonator, should i feel sluggish now?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    No.
  3. #3 Re: Deleted resonator, should i feel sluggish now?
    Nov 2012
    Bay City, MI
    note i can't hear my blower because it's so loud, not because it isn't operating correctly
  4. #4 Re: Deleted resonator, should i feel sluggish now?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    3800's always sound like crap. You just made it worse.
    GPONA #1 Cyber Bully
  5. #5 Re: Deleted resonator, should i feel sluggish now?
    SE Level Member Reverant GTP's Avatar
    Iowa
    What is your total exhaust set up? Unless you have open downpipe your exhaust shouldnt ever be louder than the supercharger. Was the resonator replaced with 2.25" piping(if you have factory exhaust)? Changing the exhaust diameter too much can have a negative effect on velocity and flow.
  6. #6 Re: Deleted resonator, should i feel sluggish now?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    You say cat is going back on...? Is it off currently? If so wwithout a tune that gets rid of the codes you might be running rich..
    I deleted me resenator and it didn't make it too much louder
  7. #7 Re: Deleted resonator, should i feel sluggish now?
    Nov 2012
    Bay City, MI
    woops, meant the resonator is going back on. im currently running lean, as i installed SD headers and a 3.4 pulley while deleting the resonator all at the same time.. Still waiting for my PCM to be shipped to me. Stock cat back, except for the straight pipe in place of the stock resonator.
  8. #8 Re: Deleted resonator, should i feel sluggish now?
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Usually would run rich without codes deleted and no cat....shouldnt sound too bad....an aftermarket exhaust added to the straight pipe is when most consider installing a res/glasspack..
  9. #9 Re: Deleted resonator, should i feel sluggish now?
    St Thomas Ontario
    maybe with your 3.4 pulley your getting kr, which pulls timing and cause the sluggish feeling... idk.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  10. #10 Re: Deleted resonator, should i feel sluggish now?
    Nov 2012
    Bay City, MI
    what kind of timing should i see, im scanning with Torque.
    I did a few KR tests and it showed no detonations
    and i think with the overkill pcm if i do have any misc. KR that it will take care of that and the lean problems.
  11. #11 Re: Deleted resonator, should i feel sluggish now?
    Iowa
    Quote Originally Posted by drewhanover View Post
    Why would you think the resonator delete is the problem when you say it was all installed at the same time? Also are you running a true wideband to know that you are lean? As long as the same pipe diameter was used on your stock exhaust then it isnt the problem nor anything else you've put on.
  12. #12 Re: Deleted resonator, should i feel sluggish now?
    Antioch, IL
    I ran headers, no cat, no res into stock muffs. quiet as a bird
    2009 Challenger SRT8
    Expert at being gay.
  13. #13 Re: Deleted resonator, should i feel sluggish now?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Quote Originally Posted by Grimsin View Post
    ^^^This. If you are running a 3.4 with a stock tune (because your pcm hasnt arrived)you most likely have kr and its killing your power.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  14. #14 Re: Deleted resonator, should i feel sluggish now?
    Nov 2012
    Bay City, MI
    im guessing that's what is happening. honestly when i first put the pulley on it smelled really lean, and now it smells rich. hopefully the problem goes away when i put the new pcm on. I'm having problems getting torque to read my KR, it just always says zero, so that's pretty much useless
  1. Deleted my EGR (Pics)
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2011, 02:03 AM
  2. So my EGR is deleted
    By KeithGTP03 in forum General Tech Discussion
    Last Post: 03-08-2011, 11:44 PM
