Thread: Front Brakes Locking up and brake pedal feels hard to push.
Results 1 to 6 of 6
  1. #1 Front Brakes Locking up and brake pedal feels hard to push.
    Feb 2013
    Phoenix,AZ
    What is causing my front brakes, mostly the left to start not wanting to come to a stop unless I press harder and then they lock up. Sometimes the ABS light comes on, sometimes it doesn't. It's getting worse and more common everyday. Anyone experienced this on a base 2007 model?
  2. #2 Re: Front Brakes Locking up and brake pedal feels hard to push.
    could be a bad brake booster, if the brake pedal feels the same with the car off.
    or a bad master cylinder if its hitting the floor.
    the abs light could be a bad hub. bad hubs will also make the brakes feel funny. when the hub is bad it moves side to side, then the caliper has a hard time holding the rotor tight.
    jack up each tire, lugs tight, then push and pull the top of the tire, you can watch the rotor where it meets the brake pads for movement, as well as feel it move if its loose.
    also check the level in the master cylinder if its low the brakes dont feel right as well.
  3. #3 Re: Front Brakes Locking up and brake pedal feels hard to push.
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    How much pad you got left on there? Squeaking? Squeeling?
  4. #4 Re: Front Brakes Locking up and brake pedal feels hard to push.
    Feb 2013
    Phoenix,AZ
    No squeaking no squealing. I have had my ABS Traction control lights comung on for about a month very intermittingly, especially when I hit some bumps. Been doing alot of reading and I believe it's leading me to a bad wheel bearing hub. Fluid levels are fine and pads have at least half their life left. I bought new rotors and pads but haven't installed them yet. I believe it's the left front that is the problem. I will check them for movement. Seems this is pretty common. I have 107,000 miles now. Just replaced a vent actuator that was tapping under the dash and driving me nuts. Thanks for your input. It's scary to drive it with this brake problem.
  5. #5 Re: Front Brakes Locking up and brake pedal feels hard to push.
    Feb 2013
    Phoenix,AZ
    Two right side wheel hubs with play up and down. Not alot, but it probably doesn't take much. Thanks for all the insight. I have four new hubs, new front rotors and brakes being delivered. I'll post the result.
  6. #6 Re: Front Brakes Locking up and brake pedal feels hard to push.
    dont but cheap ebay hubs, they suck, and you'll be redoing the whole job all to soon.
    get moog or timken, or sfk iirc these run about 120 to 130 a hub and have 3 year warrantys.
  1. Replies: 2
    Last Post: 04-02-2013, 05:49 AM
  2. 03 GTP, Up Shifting and TC Locking Up Early. And Occasionally Downshifting Hard…
    By WaterBoy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2012, 10:02 PM
  3. low brake pedal
    By johnk in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2009, 07:58 PM
  4. brakes locking up on me
    By Martin 04 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2008, 09:19 AM
