Thread: some 2008 gxp help
Results 1 to 14 of 14
  1. #1 some 2008 gxp help
    Apr 2013
    illinois
    I have a 2008 gp gxp. ive had it since july 2012 and evr since I got it, sometimes my car will tell me to service the abs system, stability system, and it turns traction control off. the dealer had a guy run a test and he said it was a bad sensor around my pass. side wheel hub. said it was 250 dollars to replace. also it seems like when i hit bumps on my pass. side, it hits a little harder, like the strut is bad. i don't know much about cars, does anyone know if that's what it really is?
  2. #2 Re: some 2008 gxp help
    If the hub was tested as bad, it's bad. The hub is different than the strut, and the strut would cause bumps to seem to hit harder.
  3. #3 Re: some 2008 gxp help
    Apr 2013
    illinois
    ok. wanted to make sure. also i have to change the rotors and brake pads. any specific brand? i assume i still want slotted rotors?
  4. #4 Re: some 2008 gxp help
    I live here. DirtDog's Avatar
    Jun 2012
    You don't have to stay with drilled rotors or slotted. Its more for looks.
  5. #5 Re: some 2008 gxp help
    do the hub when you do the brakes. you need to take the bakes off to change the hub. new hub cost 130 ish new in your hand with a 3 year warranty. its a 1 hr job tops if you never did one before.
    only odd ball tool you need is a 34 or 36 mm socket, a 1/2 drive breaker bar and a pipe to get the axle nut off.
  6. #6 Re: some 2008 gxp help
    Jun 2012
    Also if its ur first time the nut that you need the 34mm socket and breaker bar for is easier to break loose with the weight if the vehicle sitting on the tire so it don't move.
  7. #7 Re: some 2008 gxp help
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    The bad sensor he's talking about is the wheel speed sensor, which is part of the hub assembly. Basically, this sensor tells the computer how fast that wheel is spinning. When you brake hard and lock up a wheel, this sensor will read 0, indicating that the wheel is locked up and you're skidding. This tells the ABS to kick in.
    Replacing hub assemblies is pretty easy, and like scottydogs said - do the brakes/rotors when you do the hub assembly since the hub assembly is what the brake rotor sits on (the piece with the lug bolts that then hold the wheel on...got it?) Not a bad time to do the struts either, since everything is out of the way, but how many miles are on the car? I wouldn't think an '08 would need struts already...but I've been wrong before...
  8. #8 Re: some 2008 gxp help
    Oct 2012
    Union, OH
    Quote Originally Posted by marines542 View Post
    which is when it's REALLY nice to have rims with no center cap...lol
  9. #9 Re: some 2008 gxp help
    Jun 2012
    Oops...the stock gxp rims do
  10. #10 Re: some 2008 gxp help
    Oct 2012
    Union, OH
    Seems alot of them do now...When I did mine, (not a GXP, but still) I had to take the tire off, and put the spare on the lower it back down to get the axle nut loose. SUCH a PITA.
  11. #11 Re: some 2008 gxp help
    one trick is to drop a 6 inch extension in the fins of the rotor to keep the axle from turning, or put the spare tire on, most spare tires have the hole in the middle., then lower the car to the ground, then take the bolt off.
  12. #12 Re: some 2008 gxp help
    Apr 2013
    illinois
    it has 71000 miles
  13. #13 Re: some 2008 gxp help
    Apr 2013
    illinois
    thanks guys for the help. im not much of a mechanic, but my dad is. ill take this information to him
  14. #14 Re: some 2008 gxp help
    Oct 2012
    Union, OH
    Good luck, man. And remember - there's enough info on this forum to pretty much rebuild your entire front end...
  1. Looking for L.E.D lights for a 2008 GP
    By pappii46544 in forum Introductions/Noob Questions
    Last Post: 09-18-2011, 09:20 PM
  2. 2008 GXP. Where to start?
    By elpasogxplover in forum 5.3L V8 (LS4)
    Last Post: 01-30-2010, 11:16 PM
  3. 2008 gxp
    By robd5078 in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 11:31 PM
  4. HID issue in 2008 GP
    By afish70 in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2009, 05:42 PM
  5. Bgpm 2008
    By webracin in forum Shows and Events
    Last Post: 01-22-2008, 02:19 PM
