Thread: Charging system failure error message
Results 1 to 19 of 19
  1. #1 Charging system failure error message
    Jan 2013
    Mascoutah Illinois
    I have an 06 Grand Prix and I get a " Charging system failure" message on my message center. When I get the message My car acts like the battery is dead and won't start. I have had the battery tested and it tests good. What else could caus ethis error message?
  2. #2 Re: Charging system failure error message
    dirty or bad grounds, or the alt is bad.
    you can have that tested as well. test the battery volts car running, and off, when running you should see 13 to 14 volts or a bit more. off no less then 12 volts.
    you can also have the battery load tested. not sure if they did that for the bat test.
  3. #3 Re: Charging system failure error message
    Jan 2013
    Mascoutah Illinois
    The battery was loaded tested and showed fine. When this happens it starts right away when its jumped. Also if I have the key in ACC mode it will do it also.
  4. #4 Re: Charging system failure error message
    Dec 2012
    Where 4T65E's were born
    Your charging system is apparently not working correctly, and your battery is supplying all of the power to the car even while running. Either your grounds are dirty like scotty said(rather unlikely if there were no symptoms until this point) or your alternator has stopped functioning. I'd suggest to check system voltage while the car is running to make sure it's 13.5-15 volts. If you can't do that, advance or another auto parts store will if you can get the car there.
    Sold.
  5. #5 Re: Charging system failure error message
    SWPA
    If its to the point where your car doesn't want to start, then yes, it sounds like the alternator is on its way out. I got this message 2 or 3 times over the last 2 years, but it was due to a momentary overcharge.
  6. #6 Re: Charging system failure error message
    SE Level Member dimebro84's Avatar
    May 2013
    ohio
    2004 pontiac grand prix, check tire pressure, charging system failure, check engine soon lights all come on and has been on for a while like 2 months. I have been to both autozones in my town and penzoil and walmart and all of them cant get a code from the car. Every so often "reduced engine power" comes on and you cant accelerate anymore and very hard to turn. Have to pull over and shut off and open door then start it back up to b able to use car properly but yet again the other 3 lights come back on the DIC pllleeeaassssee help thank you
    Dimebro84
  7. #7 Re: Charging system failure error message
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    my 2004 was getting errors for ABS/TRAC/STABILITY AND BRAKES...and then the charging system failure light happened and the DIC, HUD, radio and IPC all lost power...car still starts up after 2-3 key turns and will idle and drive fine..everything i listed still will not display at all...unless i remove IGN1 relay under the hood...but doing that the car wont start ...im looking at the BCM as a potential culprit
    edit: i have replaced a few parts from a known 100% working 2004 gtp with the same options...
    ignition switch, under hood fuse box, dash fuse junction, multiple relays,battery, alternator
    COMP G
  8. #8 Re: Charging system failure error message
    Dec 2012
    Make sure it's not the ignition switch
    Sold.
  9. #9 Re: Charging system failure error message
    Jan 2016
    NY
    I too am having TRAC/STABILITY/BRAKE SYSTEM warnings on my DIC. The other day I went out to start it and nothing happened. We jumped it and it was undercharging. Ran a couple of tests and figured out that the alternator was bad. It then overcharged the battery and the car went into a loss of power mode. No shifting into 4th in manual mode. Both the alternator and battery were under warranty since they were less than a year old. Now I am getting charging system failure notifications again. The last one the voltage was reading 14.22. Under acceleration the voltage was dropping but as soon as I took my foot off the gas the voltage would increase. I have an 2007 Pontiac Grand Prix GXP with the 5.3L V8. Any suggestions???
    Sent from my XT1254 using Tapatalk
  10. #10 Re: Charging system failure error message
    Enfield, CT
    Might have to do with the battery current sensor. That's my guess.
  11. #11 Re: Charging system failure error message
    Jan 2016
    NY
    Where is that located?
  12. #12 Re: Charging system failure error message
    Enfield, CT
    Right on the battery cable right near the battery posts
    Sent from my LG G3
  13. #13 Re: Charging system failure error message
    Jan 2016
    NY
    We unhooked the alternator from the "the brain" of the car and the voltage held steady at 13.66. It is still throwing the charging system error on my DIC. The things it doing doesn't make sense
  14. #14 Re: Charging system failure error message
    Enfield, CT
    Here you go. This is most likely your issue.
    http://ls1tech.com/forums/ls4-perfor...g-problem.html
    Sent from my LG G3
  15. #15 Re: Charging system failure error message
    Jan 2016
    NY
    Thank u. I just heard something that I haven't heard come outta my boyfriend in the past 5 days..."it makes sense, especially since we unplugged it from the "brain" and let the alternator work for itself
  16. #16 Re: Charging system failure error message
    Jan 2016
    NY
    My vin says that it could be 5 or 10V sensor. How do I check to see which one it really is? Which wires?
  17. #17 Re: Charging system failure error message
    Enfield, CT
    Can you see a part number on the sensor?
    Sent from my LG G3
  18. #18 Re: Charging system failure error message
    Enfield, CT
    IIRC, you test the voltage on the middle wire. It'll either read 10 volts or 5.
    Sent from my LG G3
  19. #19 Re: Charging system failure error message
    Jan 2016
    NY
    Ok thank you. I haven't had a chance to look for the part number yet
  1. Charging system failure message
    By cmoney23 in forum General Tech Discussion
    Last Post: 07-17-2019, 08:37 AM
  2. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  3. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
