Thread: abs/traction control problems.
Results 1 to 2 of 2
  1. #1 abs/traction control problems.
    Jun 2012
    When i start my 04 gtp, both lights come on and the service msg comes up. Are these do to a bad abs sensor, or a bad wheel speed sensor?
  2. #2 Re: abs/traction control problems.
    Max Cook
    Guest
    Wheel bearing/sensor issue. Unless the wire just came unplugged or something along those lines you probably need a new wheel bearing (comes with sensor). Very common. I replace them more than I change my oil.
  1. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  2. Traction Control Problems
    By 04srmGTP in forum 5.3L V8 (LS4)
    Last Post: 10-18-2012, 02:00 PM
  3. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  4. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  5. 2001 gt traction control problems
    By kirkq20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2009, 08:24 PM
