Thread: Older Aeroforce vs newer aeroforce
Results 1 to 11 of 11
  1. #1 Older Aeroforce vs newer aeroforce
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Is there any differences between the older Aeroforce's and the newer ones?
  2. #2 Re: Older Aeroforce vs newer aeroforce
    Max Cook
    Guest
    Yeah. Mine is old as ****. I cant change the colour, and there are quite a few other options missing. I dont have a direct list but yes. Depends on how old and how new too obviously.
  3. #3 Re: Older Aeroforce vs newer aeroforce
    If it doesnt have the 2 lights on the face of the gauge, they are pretty worthless. The new design has way more features and is better to use.
    The older style also can't be fixed if there ever is a problem with it.
  4. #4 Re: Older Aeroforce vs newer aeroforce
    Apr 2011
    Vassar, Mi
    Older ones suck, you can tell by if it has a jumper on the back and if it has a tag on the back. Newer ones have the jumper. Mine has two lights on the face and it still sucks compared to the newer ones. You can't use the lights for anything except shift light and on mine even that won't program, it won't do case learn, it won't do cyclic....few other annoyances. Would love to be able to use the lights for KR.
    http://www.grandprixforums.net/aerof...tor-76413.html
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  5. #5 Re: Older Aeroforce vs newer aeroforce
    Jan 2012
    New York
    How can you tell how old they are besideds the 2 lights on the face?
  6. #6 Re: Older Aeroforce vs newer aeroforce
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by Anthony Smith View Post
  7. #7 Re: Older Aeroforce vs newer aeroforce
    Jan 2012
    New York
    Oh my bad missed that lol
  8. #8 Re: Older Aeroforce vs newer aeroforce
    Jan 2012
    New York
    ok so i have it all hooked up, but i cant figure out where to plug an add a fuse into on the side fuse box (2004 GP) so that it shuts off when the car is off.
  9. #9 Re: Older Aeroforce vs newer aeroforce
    Jan 2012
    New York
    Scratch that got it figured out.
  10. #10 Re: Older Aeroforce vs newer aeroforce
    Florida
    My old one didnt have all the controls then new ones have such as case learn fan controls cyclic scan. But the shift lights worked. Over the many years of Florida heat my screen died so I sent it back to them for repair. I was shocked when I plugged it in to find they had sent me a newer unit. I have the controls and the lights are now Kr activated.
  11. #11 Re: Older Aeroforce vs newer aeroforce
    Jan 2012
    New York
    Yeah got it all hooked up and has all the controls and options. And it is the newer one.
  1. What does an aeroforce do???????
    By Doug 97 gtp in forum General Tech Discussion
    Last Post: 01-21-2013, 10:43 AM
  2. Aeroforce
    By tayl5645 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:39 AM
