Dee23
Its most likely the lower motor mount on the passenger side if you can here it coming from that side and most likely the tranny mount if the sound is coming from the driver side. Check all your mounts, doing a load test is a good way to see if your mounts have any play and you will need someone to watch the mounts while you torque break it. Also, every time you change gears your motor will move a bit and depending on if the motor/tranny mounts are bad or not you'll have either a lil movement or a big annoying snapping/jerk sound
Dee...
