Thread: grand Prix losing coolant while off
Results 1 to 9 of 9
  1. #1 grand Prix losing coolant while off
    Oct 2012
    Seattle
    No discolouraton in my oil and no leaks i can see under car but my coolant is dissapearing while my car is off...this causes my car to overheat whenever i drive it any suggestions as to what it might be? need to get this fixed asap so any help is greatly appreciated
  2. #2 Re: grand Prix losing coolant while off
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    check the cap
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: grand Prix losing coolant while off
    Any white smoke out the back when started?
  4. #4 Re: grand Prix losing coolant while off
    Oct 2012
    Seattle
    yes
  5. #5 Re: grand Prix losing coolant while off
    What motor?
    Sounds like the intake gaskets are shot and need of replacement ASAP before any further damage to the motor can happen.
  6. #6 Re: grand Prix losing coolant while off
    Oct 2012
    Seattle
    What motor?
    3.8l v6 its a base model, theres white smoke from the middle of the engine as well
  7. #7 Re: grand Prix losing coolant while off
    Apr 2013
    White Lake
    It sounds like a blown gasket to me. My brother was having same problems losing coolant and took it in to find out blown gasket.
  8. #8 Re: grand Prix losing coolant while off
    SE Level Member mintygp's Avatar
    Mar 2013
    Winterpeg, Canada
    Take your car to a mechanic and tell him what happens, your engine needs surgery.
  9. #9 Re: grand Prix losing coolant while off
    When you say GP base model 3.8L without mentioning the year, this comes to mind more than an intake gasket.
    http://www.grandprixforums.net/97-03...ure-60667.html
    However while doing the work, I'd suggest plugging the coolant ports and doing the intake gaskets
    http://www.grandprixforums.net/how-mod-lim-46931.html
    Not sure if this is your issue from the little info you were able to provide. Hopefully the info helps. One way to see if the UIM has fiailed is to pull the throttle body (reusable gasket) and look around the EGR stovepipe. If it's wet, you want to address that asap.
  1. Losing coolant but no leaks?!?!?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-20-2012, 09:08 PM
  2. '00 GT Losing oil and coolant + overheating
    By famous556 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2012, 02:16 AM
  3. Car losing coolant think it is Lower intake gaskets what do you think..
    By railmule in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2011, 10:20 AM
  4. Losing coolant
    By MyPrixGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 07:18 AM
  5. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
