Thread: goofy gas gauge
Results 1 to 11 of 11
  1. #1 goofy gas gauge
    Bellevue, Neb. Close to Omaha
    Anybody out there ever change the fuel level sensor on a '04 Grand Prix?
    I bought the repair kit and I'm going to take a crack at it to correct the erratic behavior of the gas gauge on our Grand Prix.
    I watched a You Tube video of someone doing this task on a 2001 Bonneville. It didn't seem so bad, but maybe there's a trick or two that I may have not heard.
  2. #2 Re: goofy gas gauge
    I've done it, pretty straight forward, just did what the video did and re-intalled. Been working good for almost 2 years now.
  3. #3 Re: goofy gas gauge
    Yeah it helps that there is an access panel to the fuel pump in the trunk so the fueld tank doesn't have to come out. It looks like the sensor just clips on to the fuel pump module.
    Did you have any issues?
  4. #4 Re: goofy gas gauge
    I just swapped the arm piece out. The fingers were wore off, so I just took that part off the pump and the part I bought off ebay and just did a straight swap.
    The connectors were different on my fuel pump, so it wasnt plug and play.
  5. #5 Re: goofy gas gauge
    Feb 2013
    USA
    yep pretty easy did mine last week. check the line going from pump to top of unit make sure its not brittle or cracked! mine was and i hate doing something more than once! also lube your o-ring seal it goes in way easier!
  6. #6 Re: goofy gas gauge
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    anybody have any advice/links for doing a similar fix to a 02 GT?
    02 sedan, top swap
  7. #7 Re: goofy gas gauge
    Went well since there is an access panel in the trunk. Take your time and allow the fuel to run back in the tank before lifting the pump out.
    Once the fuel pump is out of the tank, the fuel sensor can easily be swapped out. There's a couple of plug-ins, route your wiring the same as the original and clip the sensor to the pump. A new clip for the sender is provided.
    The o-ring was too large for my fuel pump and I couldn't lock the ring back. I cleaned and re-used the original ring and it fell right back together.
    This was $19 well spent to correct an erratic fuel gauge.
  8. #8 Re: goofy gas gauge
    Dec 2012
    Where 4T65E's were born
    Could you post the part you used? I can only find this Dorman OE Solutions 911-008 - Fuel Level Sensor | O'Reilly Auto Parts
    Sold.
  9. #9 Re: goofy gas gauge
    Dorman part number 911-008 is what I bought on Rock Auto. It was $18.89.
  10. #10 Re: goofy gas gauge
    Dec 2012
    Oh thanks. Same part, different price.
    Sold.
  11. #11 Re: goofy gas gauge
    Aug 2011
    Troy, Michigan
    Fuel line is under pressure. Relieve at injector rail or be ready to catch some gas in towel. Also have tank 2/3 rds empty.
  1. Goofy negative terminal lock on battery
    By laferri2 in forum 5.3L V8 (LS4)
    Last Post: 10-16-2012, 03:24 PM
  2. Goofy downshifting, particularly when cold
    By Ophidia in forum General Tech Discussion
    Last Post: 12-09-2011, 03:04 PM
  3. Rear speakers acting goofy
    By kalikidd6600 in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2010, 08:39 PM
  4. After CAI install got goofy on me!?!?!?
    By nikhackgt2 in forum General Tech Discussion
    Last Post: 02-23-2009, 02:00 AM
