Thread: Dogbone Engine Mount Play
Results 1 to 20 of 27
  1. #1 Dogbone Engine Mount Play
    Dec 2012
    Where 4T65E's were born
    So far I've driven two cars with the GM 3800, mine and the family's Impala. It seems like from a dead stop and lightly tapping the gas, the impala has more of an instant feeling of torque. I always thought it was because it has tough winter tires on the front, where mine has Michelin Symmetry's. I read somewhere on these forums that the Dogbone mounts can have a good effect on something like that, so I decided to check the amount of play my Dogbone mounts have. This is what I found:
    I compared it to the 2003 Impala as well. My mounts have much more play than the Impala's has, at both the place it mounts to the engine, and where it connects to the frame. Both cars have the same mileage, 109k. Could this be why I feel a difference in immediate power?
    Last edited by 02NavyBlue; 03-08-2013 at 09:18 PM. Reason: Added year of Impala. It's an 03, where mine's an 02. Both are Series II
    Sold.
  2. #2 Re: Dogbone Engine Mount Play
    Ohio
    Flip the bushings in the core support mounts...(the square ones) or get poly mounts.
  3. #3 Re: Dogbone Engine Mount Play
    Dec 2012
    I've heard that can increase vibration. I really would like to restore like-new operation, and maybe flip the mounts. But threre is play where it meets the engine bracket too, flipping alone won't fix that. Do they sell just the rubber bushings?
    Sold.
  4. #4 Re: Dogbone Engine Mount Play
    Ohio
    Yeah you can get just the stock replacement bushings.
  5. #5 Re: Dogbone Engine Mount Play
    Dec 2012
    That must be a dealer item because the auto parts stores I'm looking at online just have the mounts(with bushings) and they're fairly expensive.
    Sold.
  6. #6 Re: Dogbone Engine Mount Play
    Pennsylvania
    I think you're looking at two different generations of bushing. New ones are fuller and stiffer. Might be able to get a set of clamshells locally or from one of the guys that occasionally parts out an 04+ car here.
    Also, even if you went full poly on both upper mounts, you won't feel a difference in vibration.
  7. #7 Re: Dogbone Engine Mount Play
    Quote Originally Posted by SlowNA06 View Post
    I sure as hell did. Made the doggies stock again and it cut it by about half.
  8. #8 Re: Dogbone Engine Mount Play
    Flipped stock bones are still a decent change.
    Poly (squares and bushings) will vibrate quite a bit.
  9. #9 Re: Dogbone Engine Mount Play
    Pennsylvania
    I can't feel feelings apparently.
  10. #10 Re: Dogbone Engine Mount Play
    My car has vibrational issues.
  11. #11 Re: Dogbone Engine Mount Play
    You should go see a vibrachologist
  12. #12 Re: Dogbone Engine Mount Play
    Pennsylvania
    I've heard good things about their massages.
  13. #13 Re: Dogbone Engine Mount Play
    I could honestly take the car to one.
    Did new mounts all the around 53K ago. Aluminum sub, poly fronts and doggies. Changed the doggies back to stockers after having trouble with stop lights.
  14. #14 Re: Dogbone Engine Mount Play
    You should ask about the backroom one, you know...option 3.
  15. #15 Re: Dogbone Engine Mount Play
    Dec 2012
    Ok well I took your advice and flipped the Dogbone mounts. That got rid of the movement at that spot. Since I had movement at the engine side of the mount as well, I stuck a small nail in the slot before putting the bolt back in. No harm done, and there's no movement there either. I also made a video of my own because before I learned on my own how to flip them, I looked and could not find a detailed write-up or video on the forums or all of Youtube.
    Sold.
  16. #16 Re: Dogbone Engine Mount Play
    GT Level Member Shiftingshaddow's Avatar
    KC
    that was a pretty cool trick on the flip there. i was messing with those today and decided to just say screw it. i didn't want to mangle them up. i will try that maybe tomorrow.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  17. #17 Re: Dogbone Engine Mount Play
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    If you get polys get intense ones hardly any vibration in my car and that's what I have but yes the flipped do work well also but I felt a much larger difference with the poly
    2003 Pontiac Grand Prix GTP, thrasher intake, intense poly upper mounts, 06+ Impala dual piston calipers, 88k miles
  18. #18 Re: Dogbone Engine Mount Play
    Dec 2012
    Quote Originally Posted by Shiftingshaddow View Post
    I actually did the same thing. I gave up the first time and thought of it randomly while doing something else.
    Quote Originally Posted by jake91 View Post
    Well even with the serious amount of play that I got rid of, I didn't notice that big of a difference, really. But then again I'm not the type that's always doing fun stuff with my car, just the average driver who gets on it once in a while.
    Sold.
  19. #19 Re: Dogbone Engine Mount Play
    Jun 2012
    mesa az
    You sound like me then only reason I got polys is because I broke my engine mount and figured why not upgrade
  20. #20 Re: Dogbone Engine Mount Play
    Portland Oregon
    I have poly everything right now. I'm contemplating just going to new stock everything again. I think I'm getting old. Either that or it's the xp cam and no balance shaft that's getting on my nerves.
  1. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  2. Engine mount question
    By goldgp in forum General Tech Discussion
    Last Post: 09-24-2010, 08:47 PM
  3. ????engine mount???
    By 03GPSE in forum Engine
    Last Post: 09-05-2010, 12:30 PM
  4. lower engine mount?
    By RichCresci in forum General Tech Discussion
    Last Post: 11-30-2008, 10:47 PM
