Thread: PCM mounting ?
Results 1 to 7 of 7
  1. #1 PCM mounting ?
    Feb 2013
    Ohio
    Do I need to get the PCM mounting plate, or can I just drill holes to mount PCM on 02 gtp . What do you guys do ?Thanks.
  2. #2 Re: PCM mounting ?
    Dec 2010
    DMV
    Neither. Just leave it sitting there. It's shockproof
  3. #3 Re: PCM mounting ?
    SE Level Member schollianmj's Avatar
    Dec 2012
    Virginia
    I put a heavy bead on the shelf an let that cure, then sat the PCM on top of that and used thick assed zipties to hold it down.
  4. #4 Re: PCM mounting ?
    I just left mine lay it's been fine for 2 years.
  5. #5 Re: PCM mounting ?
    Sep 2011
    Copperas Cove, TEXAS
    Yup, let it just sit there.
  6. #6 Re: PCM mounting ?
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    if you want to mount it to something other guys on here have used s10 pcm mounting plates and just drilled new holes for that... mines ziptied and does just fine
  7. #7 Re: PCM mounting ?
    Nov 2011
    NY
    Mounting tray = $10-$15... If you feel the need.
  1. HID Mounting?
    By ebibby in forum Visual/Body Modifications
    Last Post: 01-10-2013, 10:09 PM
  2. Mounting Kit
    By Mrc728 in forum Audio, Security & Visual Electronics
    Last Post: 11-12-2011, 01:36 PM
  3. PCM mounting
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 03:50 AM
  4. Mounting Kit??????
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2008, 02:08 AM
  5. GPS Mounting
    By iflycessnas05 in forum General Tech Discussion
    Last Post: 06-26-2008, 08:36 PM
