Thread: Spark plug question
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Spark plug question
    SE Level Member BigKev2403's Avatar
    Feb 2013
    Cleveland Ohio
    Quote Originally Posted by buickman104 View Post
    What size pulley were you running on your 2002 ssei with those mods?
    It was a 3.4
  2. #22 Re: Spark plug question
    Feb 2013
    Cleveland Ohio
    All this talk about plugs I forgot to ask, how should I gap them? I plan on going to grab some seafoam, plugs, and oil here in an hour or so....
    I'm gonna get the Autolite 104, what should I gap them at?
    180* tstat
    Airraid throttle body spacer
    3" catted dp w/magnaflow cat back
    cai
    pcm tune
    And I think that's about all I have
  3. #23 Re: Spark plug question
    1) remove that throttle body spacer, it's doing nothing for you but creating a leak in the future.
    2) run stock heat range plugs, you have no reason to run 104s since you're on the stock supercharger pulley.
    3) stop jumping the gun with this. you're way too early.
  4. #24 Re: Spark plug question
    Feb 2013
    Auburn, Indiana
    I have a very similar set up as him and run the 104's with no problem. I had mine tuned by PRJ and he stated they would work fine and have.
  5. #25 Re: Spark plug question
    they will work fine, but they aren't ideal in any situation. there's no reason to run a colder plug on a stock boost level unless you like wasting gas/money.
  6. #26 Re: Spark plug question
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    ^he said that he was going to be dropping to a 3.4 pulley
  7. #27 Re: Spark plug question
    going. to. be.
    meaning do it after you drop the pulley. it only takes half hour to do the plugs.
  8. #28 Re: Spark plug question
    Hope your not planning on doing this to save the $12 that spark its cost. Wait until you drop pulleys then change.
    04 Comp G.
  1. Spark plug gap question
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-07-2012, 12:18 AM
  2. PCM and spark plug question
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2011, 05:31 PM
  3. Spark plug question
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 03:44 PM
  4. Spark Plug question
    By Kenny75k in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2010, 09:04 PM
  5. Spark plug question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 05:36 PM
