Thread: Starting Issue
Results 1 to 15 of 15
  1. #1 Starting Issue
    GT Level Member GrandPriest24's Avatar
    Jan 2013
    Michigan
    When i go to start up my car it will crank alittle longer then usual any idea what that could be?
  2. #2 Re: Starting Issue
    Jan 2013
    Michigan
    i was thinking starter or battery
  3. #3 Re: Starting Issue
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Do you mean it cranks slower or just takes more cranking?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  4. #4 Re: Starting Issue
    Jan 2013
    Michigan
    not positive on how to explain it like it just takes look usually slower and longer
  5. #5 Re: Starting Issue
    Nov 2012
    Madison
    Quote Originally Posted by GrandPriest24 View Post
    Slower crank would more than likely be battery going...take it in and have it checked, they do it for free or maybe its just your hearing going from the new exhaust
  6. #6 Re: Starting Issue
    St. Louis
    Might give your cables a good cleaning and tighten them up.
  7. #7 Re: Starting Issue
    Jan 2013
    Michigan
    ill take it in tomorrow and have it looked at i figured it would be the battery it sounds weaker and slower
  8. #8 Re: Starting Issue
    Dec 2012
    Where 4T65E's were born
    Since there was a comment about exhaust, I have heard that a less restrictive exhaust can cause an engine to crank just a little more than with a normal one. Basically meaning a little restriction helps it to start quicker. I don't know if it's true or not.
    Sold.
  9. #9 Re: Starting Issue
    Jan 2013
    Michigan
    that wouldn't be it because before i did anything to the exhaust it was like this but on and off
  10. #10 Re: Starting Issue
    have you tried hooking up jumper cables to your battery? if it cranks faster and fires right up, your battery's on its way out.
  11. #11 Re: Starting Issue
    Jan 2013
    Michigan
    ill try that out thanks
  12. #12 Re: Starting Issue
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    if these suggestions dont work, check your fuel pressure. If you lose all your pressure when you start the car and turn it off, it could be a bad fuel pressure regulator. I thought it was this and replaced it, but didn't fix my starting issue. I then replaced my fuel filter, it needed it anyways, and didnt fix my long cranking. Then i put a new fuel pump in and now it cranks up first time every time. Before, it would crank anywhere from 2-7 seconds.
  13. #13 Re: Starting Issue
    Dec 2012
    When I went to look at used Grand Prix's, 3/4 of them cranked longer than they should. Years were 05, 04, and 05. Then when I went to look at the one that I did end up buying (02), it started up real quick. It had just been tuned up a few thousand miles before, and the mass air flow sensor had been replaced. I feel that longer cranking can be caused by the mass air flow sensor. Of course like the above replies, fuel pressure is a possibility as well. Try keeping the key in the on position for a few seconds before cranking and see if the fuel pump running longer before starting makes a difference. That could indicate the one way valve being bad. So many possibilities. Here's a video on how my 3.8 starts in two different conditions.
    If it takes longer than my longest when cold, but when your engine is warm, I'd be wondering too. Miles? Tuneup done?
    Sold.
  14. #14 Re: Starting Issue
    Jan 2013
    Michigan
    yeah the first time you did it is how mine is everytime idk if it is weather because it has been from 10-40 degrees in michigan but it has been doing it for a while now i've heard so many different things i want to be sure before doing anything
  15. #15 Re: Starting Issue
    Dec 2012
    Does it idle smooth once the high idle goes away? My friends car cranked less after cleaning his throttle body, and idled smoother. It was extremely dirty, and at only 67,000 miles. There are many things that can cause longer than usual cranking. Nobody can really say for sure without doing some diagnostics. That first crank on the video was the longest it ever was, I should have also mentioned that the battery had been out for a few hours, and I had just put a new one in right before starting it up.
    A tuneup by 100k is necessary(Plugs, wires, air filter), checking the TB for carbon buildup, Cleaning MAF Sensor, Checking for vacuum leaks if you answered no to the idle question^, Checking the state of the battery(State of charge, and life of the battery expressed in CCA, auto parts stores can check this for free) If cranking is slow and battery is good, a voltage drop test can be done, Fuel injector cleaner, checking fuel pressure(also replacing fuel filter), compression testing, etc. The list could go on. I pretty much put it in order.
    Sold.
  1. Starting issue
    By Zach Chapman in forum General Grand Prix Discussion
    Last Post: 12-25-2012, 10:11 AM
  2. Please someone help me out here, starting issue.
    By Brickie in forum General Tech Discussion
    Last Post: 01-12-2012, 12:10 AM
  3. Please someone help me out here, starting issue.
    By Brickie in forum Off Topic Discussion
    Last Post: 01-09-2012, 12:30 PM
  4. 97 Gtp starting issue
    By DukesGTP in forum Off Topic Discussion
    Last Post: 10-29-2010, 06:35 PM
  5. 04 starting issue
    By peppy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2010, 02:45 AM
