Thread: 3100 engine swap to 3800
Results 1 to 4 of 4
  1. #1 3100 engine swap to 3800
    SE Level Member carlover89's Avatar
    Sep 2011
    Sheboygan
    Looking at swapping engine/ trans from my 95 grand prix se with a 97 grand prix 3800. Anyone know of a write up? Cant seem to find any. I know the engine mount will need some work for it fit.
  2. #2 Re: 3100 engine swap to 3800
    St. Louis
    If you search the 3.1 section this comes up all the time.
    Quoted from FFDP- You'll need the engine, wire harness, pcm and a few other odds and ends.
  3. #3 Re: 3100 engine swap to 3800
    Dec 2012
    troll land
    If its 97 gt youll need a 96 regal harness(with a few wire changes), if its a 97 gtp, youll need a 98-99 monte z34 harness and dp along with the driver side axle, pcm from the same car. Also if 97 gtp donor youll need to do a hybrid pass cv
  4. #4 Re: 3100 engine swap to 3800
    Florida
    I did this swap on my 96 Z34.
    ok you say its a 95se. then you will need some work, as your car is not obd2 compliant. you will need a cluster from a 96+ car, adjustments to the dash harness maybe, deff will need a harness for the 3800 the 98/99 Z34-ltz harness is a perfect and may need a few minor pin changes at the c-100 connector on the fire wall. I have a zip file with the harness pinouts if you need it. the hybrid axle is only needed if you are installing a 4t65-HD out of a GTP. if the donor car is just an l36 you wont need to do that. you prob will need the axles from a 98/99 Z as well. if your looking to install headers or think you may one day want them, cut up the firewall now. you need to remove about a 12"x10" section of firewall for a downpipe to clear. you will also need different power steering lines, ac lines (maybe), and throttle cable may not work... also the trans shift cable is different but your 95se may work too.
  1. Will the L26 (3800 aspirated) swap out my 03 GPSE 3100??
    By nevillekilcc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2012, 05:29 AM
  2. Will the 2003 L67 SC 3800 swap out my LG8 03 GP 3100??
    By nevillekilcc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2012, 09:48 AM
  3. 1998 Grand Prix 3100 engine swap to a 2001 Buick Regal 3800
    By glisarjustin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2012, 09:16 AM
  4. 98 grandprix engine swap 3100 to 3800
    By TheBlackReaper in forum General Tech Discussion
    Last Post: 05-16-2011, 01:49 PM
  5. 3100 to 3800 swap questions
    By MRJ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2009, 09:52 AM
