Thread: Rough idle
Results 1 to 14 of 14
  1. #1 Rough idle
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    So my cars starting to get a rough idle and I don't know what it is
    Can someone please help?
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: Rough idle
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    seafoam it
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Rough idle
    GT Level Member PontiacL32's Avatar
    Sep 2012
    Murray, ky
    Is the check engine light on?
    2005 Grand Prix GTP, 170,000 miles. Speed daddy headers with no cat, cone intake, MSD wires, flipped dog bones, transgo shift kit FOR SALE.
    2004 GTO six speed, stock for now.
  4. #4 Re: Rough idle
    Hmm maybe a little more info would help you out a lot.
  5. #5 Re: Rough idle
    Dec 2012
    grand rapids
    Light isnt on
    And my whole car shakes at idle
    But it still
    Idk what else to tell you
  6. #6 Re: Rough idle
    Sep 2012
    bridgeport,NY
    seafoam 8 bucks and done
  7. #7 Re: Rough idle
    Maybe what you drive would help
  8. #8 Re: Rough idle
    Sep 2012
    bridgeport,NY
    a stock gt its in his sig it needs a good cleaning its plugged with carbon
  9. #9 Re: Rough idle
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Plugged with carbon?
    What?
    I think the OP should tell us what he has done lately for maintence and repairs. Like plugs, wires, sensors etc etc etc.
    Maybe its got a huge vacuum leak along with a misfire, or a motor mount is smashed the **** up and now he is feeling everything.
  10. #10 Re: Rough idle
    His sig says stock gt so it could have an l36 or l26 or l32 depending on what year
  11. #11 Re: Rough idle
    His name is also 97GP, and combine that with his sig and you get a 97 GT, like omg that was easy. L36 guys.
  12. #12 Re: Rough idle
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Never heard of a car idling rough so bad it needed seafoam to fix it. Could be a misfire, vac leak, damn just about a lot of different things. Just because there's no light doesn't mean it didn't throw a code.
    How is it when you drive? Does it smooth out? Does it only do it at idle?
    When's the last time you did plugs/wires/o2, any maintenance at all on it?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  13. #13 Re: Rough idle
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Jake.
    You need to give us more info to help you out.
    Read the above posts, and tell us all what has been done maintenance wise lately.
    At least start by checking for Vac leaks. Grab a can of carb cleaner and go to town on all vacuum lines. If the RPMs spike, well, then there's a vac leak.
  14. #14 Re: Rough idle
    Sep 2012
    bridgeport,NY
    seafoam took care of my rough idle and our motors are the same year
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Rough idle
    By 7point62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2012, 01:28 PM
  3. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  4. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
  5. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
